3M Adjustable Gel Wrist Rest features sleek design with tapered leatherette-covered gel wrist rests. Softer gel with a more cushiony feel provides optimal wrist comfort. Tilt-adjustable to help keep wrists properly aligned.
Product Description | 3M keyboard platform with wrist pillow | Product Type | Keyboard platform with wrist pillow | Product Material | Leatherette | Dimensions (WxDxH) | 49.8 cm x 26.9 cm x 2.5 cm | Manufacturer Warranty | 2-year warranty |
General | |
Width | 49.8 cm |
Depth | 26.9 cm |
Height | 2.5 cm |
Miscellaneous | |
Features | Gel filled, tilt adjustment, antimicrobial finish |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
