Every aspect of the Switch 5 is aimed at efficient, practical, every-day use, but with an undeniably premium feel.
Product Description | Acer Switch 5 SW512-52-58Q4 - 12" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Home 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Display | 12" LED backlight touchscreen 2160 x 1440 / Full HD Plus | Graphics | Intel HD Graphics 620 | Input Device | Digitizer, touchpad, digital pen, detachable keyboard | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth 4.0, 802.11a/b/g/n/ac | Battery | 2-cell - up to 10.5 hours | Features | Ambient light sensor, G-sensor, electromagnetic compass | Dockable | Yes | Security | Fingerprint reader | Colour | Grey | Dimensions (WxDxH) - tablet | 29.29 cm x 20.18 cm x 0.96 cm | Weight | 920 g | Localisation | Region: United Kingdom | Environmental Standards | - EPEAT Climate+ |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Storage | |
Main Storage | 256 GB SSD |
Display | |
Type | 12" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (10-point multi-touch) |
Resolution | 2160 x 1440 (Full HD Plus) |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Image Brightness | 350 cd/m² |
Features | Glare, CineCrystal, Mercury free, Wide Viewing Angle |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 2592 x 1944 (rear), 1600 x 1200 (front) |
Resolution | 5 Megapixel (rear), 2 Megapixel (front) |
Video Resolutions | 720p, 1080p |
Camera Features | Wide angle lens, Windows Hello |
Sound | Stereo speakers, microphone |
Input | |
Type | Digitizer, touchpad, digital pen, detachable keyboard |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad |
Communications | |
Wireless | Bluetooth 4.0, 802.11a/b/g/n/ac |
Battery | |
Technology | 2-cell Lithium Ion |
Capacity | 37 Wh |
Run Time | Up to 10.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | USB-C , Headphone/microphone combo jack , USB 3.0 |
Memory Card Reader | Yes (microSD, microSDXC) |
Miscellaneous | |
Colour | Grey |
Case Material | Anodised aluminium |
Integrated Options | Ambient light sensor, G-sensor, electromagnetic compass |
Dockable | Yes |
Features | Volume control, built-in easel kickstand |
Included Accessories | Power adapter, keyboard, active pen, stylus holder |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 920 g |
Dimensions (WxDxH) / Weight Details | 29.29 cm x 20.18 cm x 0.96 cm / 920 g - tablet , 29.29 cm x 20.18 cm x 1.2 cm / 1.27 kg - tablet with keyboard |
Sustainability Information | |
TCO Certified | - |
