Acer Chromebox CXI3 is designed for business in multiple environments whether in offices or digital signage. Get superb security and versatile connectivity for all manner of businesses.
Product Description | Acer Chromebox CXI3 - mini PC - Core i5 8250U 1.6 GHz - 8 GB - SSD 64 GB | Type | Chromebox - mini PC | Localisation | Region: United Kingdom | Processor | 1 x Intel Core i5 (8th Gen) 8250U / 1.6 GHz (3.4 GHz) (Quad-Core) | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 8 GB (installed) / 16 GB (max) - DDR4 SDRAM | Hard Drive | SSD 64 GB - M.2 | Optical Storage | No optical drive | Card Reader | Yes | Graphics Controller | Intel UHD Graphics 620 | Networking | GigE, 802.11a, 802.11b/g/n, 802.11ac, Bluetooth 4.2 | OS Provided | Google Chrome OS | Colour | Black | Dimensions (WxDxH) | 15.1 cm x 14.85 cm x 4 cm | Weight | 2 kg |
General | |
Type | Chromebox |
Product Form Factor | Mini PC |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8250U / 1.6 GHz |
Max Turbo Speed | 3.4 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 8 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2666 MHz |
Rated Memory Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 0 (empty) |
Configuration Features | 2 x 4 GB |
Hard Drive | |
Type | SSD - M.2 |
Capacity | 1 x 64 GB |
Manufacturer | Kingston |
Optical Storage | |
Type | No optical drive |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | microSD |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 620 |
Video Interfaces | HDMI |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Interface (Bus) Type | M.2 Card |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 7265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Interfaces | 5 x USB 3.1 Gen 1 (2 front, 3 rear) , 1 x USB-C 3.1 Gen 1 , 1 x HDMI output , 1 x LAN (Gigabit Ethernet) , 1 x headphones/microphone (1 in front) |
Miscellaneous | |
Included Accessories | VESA mounting kit, 2x wireless aerials |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Power | |
Device Type | Power adapter |
Power Provided | 90 Watt |
Operating System / Software | |
Dimensions & Weight | |
Width | 15.1 cm |
Depth | 14.85 cm |
Height | 4 cm |
Weight | 2 kg |
