Crisp, clear, perfect, visuals are displayed on the high-resolution screen with a 178° viewing angle. With a high-resolution display, movies and TV shows are shown in great clarity, and then share the screen with those around you with the expansive viewing angle.
Product Description | Acer Chromebook Spin 713 CP713-2W-36LN - 13.5" - Core i3 10110U - 8 GB RAM - 128 GB SSD - UK | Product Type | Chromebook - flip design | Operating System | Chrome OS | Processor | Intel Core i3 (10th Gen) 10110U / 2.1 GHz (4.1 GHz) / 4 MB Cache | Memory | 8 GB DDR4 (8 GB (soldered)) | Storage | 128 GB SSD | Display | 13.5" LED backlight touchscreen 2256 x 1504 | Graphics | Intel UHD Graphics | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax | Battery | 3-cell - up to 10 hours | Features | Accelerometer, gyro sensor | Colour | Steel grey | Dimensions (WxDxH) | 30.065 cm x 23.5 cm x 1.68 cm | Weight | 1.37 kg | Localisation | Region: United Kingdom | Manufacturer Warranty | Limited warranty - 1 year - carry-in , International travellers warranty - 1 year |
General | |
Operating System | Google Chrome OS |
Processor / Chipset | |
CPU | Intel Core i3 (10th Gen) 10110U / 2.1 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (8 GB (soldered)) |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Storage | |
Main Storage | 128 GB SSD - SanDisk |
Display | |
Type | 13.5" - IPS |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes (multi-touch) |
Resolution | 2256 x 1504 |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Image Brightness | 415 cd/m² |
Features | Corning Gorilla glass, glare, CineCrystal, 30 ms response rate |
Audio & Video | |
Graphics Processor | Intel UHD Graphics |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - HD |
Video Resolutions | 1280 x 720 |
Sound | Stereo speakers, two microphones |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard |
Communications | |
Wireless | Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax |
Wireless Controller | Intel Wi-Fi 6 AX 201 - M.2 Card |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 10 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 5 / 9 / 12 / 15 / 20 V |
Connections & Expansion | |
Interfaces | USB 3.0 , 2 x USB-C 3.1 (supports DisplayPort Alt Mode) , Headphone/microphone combo jack , HDMI |
Miscellaneous | |
Integrated Options | Accelerometer, gyro sensor |
Features | HDCP Compliant |
Included Accessories | USB-C power adapter |
Compliant Standards | MIL-STD 810G |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.37 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in , International travellers warranty - 1 year |
