The Acer Extensa combines productivity and entertainment technology in a highly portable package. It provides long battery life, letting you stay unplugged and mobile for the entire day. Complete your daily tasks efficiently with the advanced touchpad, and get optimal voice communication with the enhanced microphone and speakers.
Product Description | Acer Extensa 15 2540-51H1 - 15.6" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB DDR3L (1 x 8 GB) | Storage | 256 GB SSD | Optical Drive | DVD-Writer | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Keyboard | UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell - up to 6.5 hours | Colour | Midnight black | Dimensions (WxDxH) | 38.18 cm x 25.8 cm x 2.46 cm | Weight | 2.4 kg | Localisation | Region: United Kingdom |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 16 GB |
Technology | DDR3L SDRAM |
Speed | 1600 MHz |
Rated Speed | 1600 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 256 GB SSD - Kingston |
Optical Drive | DVD-Writer - tray |
Display | |
Type | 15.6" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Ultra Slim Design, anti-glare, ComfyView, Mercury free, Acer BluelightShield technology |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 640 x 480 |
Resolution | 0.3 Megapixel |
Sound | Stereo speakers, microphone |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 3168 - M.2 Card |
Network Interface | Gigabit Ethernet |
Features | Wake-on-LAN (WOL) |
Battery | |
Technology | 4-cell lithium polymer |
Capacity | 48 Wh |
Run Time | Up to 6.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | HDMI , 2 x USB 2.0 , USB 3.0 , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Case Material | Plastic |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.4 kg |
Sustainability Information | |
TCO Certified | - |
