Enjoy superb videos, browsing and games on a great 10.1" screen. Everything happens quickly and smoothly thanks to a powerful processor. Plus, this tablet's enhanced touchscreen sensitivity lets you tap, sketch and write with awesome precision.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Acer ICONIA ONE 10 B3-A30-K7D6 - tablet - Android 6.0 (Marshmallow) - 16 GB - 10.1" | Product Type | Tablet | Operating System | Android 6.0 (Marshmallow) | Display | 10.1" IPS TFT - LED backlight - 1280 x 800 - Multi-Touch | Processor | MediaTek MT8163 (Quad-Core) - 64-bit | Processor Clock Speed | 1.3 GHz | Storage | 16 GB eMMC | RAM | 1 GB | Supported Flash Memory Cards | microSD, microSDXC | Wireless Connectivity | 802.11a/b/g/n, Bluetooth 4.0 | Rear Camera | 5 Megapixel | Front Camera | 2 Megapixel | Navigation System | GPS | Features | USB host | Battery Run Time | Up to 10 hours | Dimensions (WxDxH) | 16.75 cm x 0.915 cm x 25.9 cm | Weight | 520 g | Colour | White | Localisation | Nordics | Manufacturer Warranty | 1-year warranty |
General | |
Display | |
Type | 10.1" IPS TFT - LED backlight |
Resolution | 1280 x 800 |
Touchscreen | Multi-Touch |
Features | 10-point multi-touch |
Processor | |
Processor | MediaTek MT8163 |
Number of Cores | Quad-Core |
64-bit Computing | Yes |
Memory | |
RAM | 1 GB - DDR3L SDRAM |
Max Supported Capacity | 128 GB |
Communications | |
Rear Camera | |
Sensor Resolution | 5 Megapixel |
Front Camera | |
Sensor Resolution | 2 Megapixel |
Navigation System | |
Receiver | GPS |
Multimedia | |
Graphics | Mali T720 MP2 |
Audio | Microphone, stereo speakers |
Expansion and Connectivity | |
Expansion Slots | 1 x microSDXC |
Interfaces | 1 x Micro-USB , 1 x headphones mini jack (3.5mm) |
USB Host | Yes |
Power | |
Voltage Required | AC 120/230 V (50/60 Hz) |
Battery | |
Technology | Lithium polymer |
Capacity | 22.4 Wh |
Miscellaneous | |
Colour | White |
Sensors | G-sensor |
Features | Volume control |
Included Accessories | Power adapter |
Compliant Standards | RoHS, WEEE |
Dimensions & Weight | |
Width | 16.75 cm |
Depth | 0.915 cm |
Height | 25.9 cm |
Weight | 520 g |
Manufacturer Warranty | |
Service & Support | Traveller warranty - 1 year |
