With the TravelMate P2, it has never been easier to work away from the office. Step up your productivity through a combination of increased processing power, portability, and durability bundled with a wide range of handy business features and advanced connectivity options. For the professional on the road, there's no better choice.
Product Description | Acer TravelMate P2 TMP215-52-5600 - 15.6" - Core i5 10210U - 8 GB RAM - 1 TB HDD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (10th Gen) 10210U / 1.6 GHz (4.2 GHz) / 6 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 1 TB HDD / 5400 rpm | Display | 15.6" LED backlight 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics | Keyboard | UK | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax, Gigabit Ethernet | Battery | 4-cell - up to 11.5 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader | Colour | Black | Dimensions (WxDxH) | 36.39 cm x 25.54 cm x 1.99 cm | Weight | 1.8 kg | Localisation | Region: United Kingdom | Environmental Standards | TCO Certified Notebooks 9, ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - carry-in , International travellers warranty - 1 year |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (10th Gen) 10210U / 1.6 GHz |
Max Turbo Speed | 4.2 GHz |
Number of Cores | Quad-Core |
Cache | 6 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 1 TB HDD SATA 6Gb/s / 5400 rpm - Toshiba |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare, ComfyView, 8 ms response rate, Narrow Border Display |
Audio & Video | |
Graphics Processor | Intel UHD Graphics |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - HD |
Sound | Stereo speakers, two microphones |
Compliant Standards | High Definition Audio |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad |
Communications | |
Wireless | Bluetooth 5.0, 802.11a/b/g/n/ac Wave 2/ax |
Wireless Controller | Intel Wi-Fi 6 AX 201 - M.2 2230 |
Network Interface | Gigabit Ethernet |
Features | Wake-on-LAN (WOL) |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 11.5 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces | 2 x USB 3.1 Gen 1 , USB 3.1 Gen 1 (with power off charging) , USB-C 3.1 Gen 1 (supports DisplayPort Alt Mode) (DC-In combo) , HDMI , VGA , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Features | MU-MIMO technology, HDCP Compliant |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | MIL-STD 810G |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.8 kg |
Environmental Standards | |
TCO Certified | TCO Certified Notebooks 9 |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in , International travellers warranty - 1 year |
