Striking the perfect balance between perfomance & efficency, TravelMate series notebooks are reliable learning companions powerful enough to handle most workloads. TravelMate P2 notebooks come with a set of handy manageability and security tools so the devices are easy to deploy and handle even without dedicated IT staff.
Product Description | Acer TravelMate P2410-G2-M-85Q8 - 14" - Core i7 8550U - 8 GB RAM - 256 GB SSD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (8th Gen) 8550U / 1.8 GHz (4 GHz) / 8 MB Cache | Memory | 8 GB DDR4 (1 x 8 GB) | Storage | 256 GB SSD | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel UHD Graphics 620 | Keyboard | UK | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell - up to 8 hours | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Black | Dimensions (WxDxH) | 34.2 cm x 23.6 cm x 2.23 cm | Weight | 1.8 kg | Localisation | Region: United Kingdom | Environmental Standards | TCO Certified Notebooks 9 | Manufacturer Warranty | International travellers warranty - 1 year - carry-in |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8550U / 1.8 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (1 x 8 GB) |
Max RAM Supported | 20 GB |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Storage | |
Main Storage | 256 GB SSD M.2 2280 - Micron |
Display | |
Type | 14" - TN |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare, ComfyView, 8 ms response rate |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - HD |
Camera Features | HDR (High Dynamic Range), 88° view |
Sound | Stereo speakers, microphone |
Audio Features | Acer TrueHarmony technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard, precision touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Features | Intel Wireless Display (WiDi) |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 65 Watt, 19 V |
Connections & Expansion | |
Interfaces | 3 x USB 2.0 , HDMI , VGA , LAN , USB 3.0 (with power off charging) , Headphone/microphone combo jack , USB-C 3.1 Gen 1 |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 1.8 kg |
Environmental Standards | |
TCO Certified | TCO Certified Notebooks 9 |
Manufacturer Warranty | |
Service & Support | International travellers warranty - 1 year - carry-in |
