The TravelMate P2 series packs powerful processors to efficiently drive you through your work day. The notebook can extend their monitor output to a second, bigger display, so you get two screens for viewing more documents and working more effectively. Crunch numbers faster with the independent numeric keypad.
Product Description | Acer TravelMate P259-M-31XT - 15.6" - Intel Core i3 - 6006U - 4 GB RAM - 500 GB HDD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i3 (6th Gen) - 6006U / 2 GHz / 3 MB Cache | Memory | 4 GB DDR4 (1 x 4 GB) | Storage | 500 GB HDD / 5400 rpm | Optical Drive | DVD-Writer | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 520 | Keyboard | UK | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell | Security | Trusted Platform Module (TPM 2.0) Security Chip | Colour | Black | Dimensions (WxDxH) | 38.16 cm x 25.9 cm x 3.02 cm | Weight | 2.4 kg | Localisation | Region: United Kingdom | Environmental Standards | TCO Certified Notebooks 9, ENERGY STAR Qualified |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i3 (6th Gen) 6006U / 2 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Rated Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA / 5400 rpm |
Optical Drive | DVD-Writer - tray |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Features | Anti-glare, ComfyView, Mercury free |
Audio & Video | |
Graphics Processor | Intel HD Graphics 520 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1280 x 720 |
Camera Features | HDR (High Dynamic Range), 720p HD movie recording |
Sound | Stereo speakers, microphone |
Audio Features | Output: Acer TrueHarmony technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, FineTip keyboard |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 41.4 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | USB 2.0 , HDMI , VGA , LAN , USB 3.0 , USB-C Gen 1 , Headphone/microphone combo jack , USB 3.0 (with power off charging) |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Features | Administrator password, system password, hard drive password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.4 kg |
Sustainability Information | |
TCO Certified | - TCO Certified Notebooks 9 |
ENERGY STAR Certified | Yes |
