The TravelMate P2 series meets various business needs. Clad in a refined textile finish, that both looks and feels great, these notebooks pack fast processors and discrete graphics to keep you productive.
Product Description | Acer TravelMate P449-G2-M-56S0 - 14" - Intel Core i5 - 7200U - 4 GB RAM - 500 GB HDD - UK | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 4 GB DDR4 (provided memory is soldered) | Storage | 500 GB HDD / 5400 rpm | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Keyboard | UK | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, NFC, Bluetooth 4.2, Gigabit Ethernet | Battery | 4-cell - up to 8 hours | Features | G-sensor | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader | Colour | Black | Dimensions (WxDxH) | 34.2 cm x 23.6 cm x 2.19 cm | Weight | 2 kg | Localisation | Region: United Kingdom | Environmental Standards | TCO Certified Notebooks 9, ENERGY STAR Qualified |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | DDR4 SDRAM |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Storage | |
Main Storage | 500 GB HDD SATA / 5400 rpm |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 220 cd/m² |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Memory Allocation Technology | Shared Video Memory (UMA) |
Camera | Yes - 1280 x 720 |
Camera Features | HDR (High Dynamic Range), 720p HD movie recording |
Sound | Stereo speakers, microphone |
Audio Features | Output: Acer TrueHarmony technology |
Input | |
Type | Keyboard, touchpad |
Keyboard Layout | UK |
Features | Multi-gesture touch pad, Acer FineTip keyboard |
Communications | |
Wireless | 802.11a/b/g/n/ac, NFC, Bluetooth 4.2 |
Wireless Controller | Intel Dual Band Wireless-AC 7265 - M.2 Card |
Network Interface | Gigabit Ethernet |
Ethernet Controller | Intel I219-LM |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 48 Wh |
Run Time | Up to 8 hours |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | 3 x USB 2.0 , USB 3.0 , USB-C , HDMI , VGA , LAN , Headphone/microphone combo jack |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Colour | Black |
Integrated Options | G-sensor |
Features | Administrator password, system password, hard drive password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter |
Compliant Standards | ACPI 5.0 |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2 kg |
Sustainability Information | |
TCO Certified | - TCO Certified Notebooks 9 |
ENERGY STAR Certified | Yes |
