Everything you need from a standard sized desktop in a fraction of the space. Maintain productivity with powerful features that keep your business running smoothly.
Product Description | Acer Veriton Essential ES2 VES2710G - MT - Core i3 7100 3.9 GHz - 4 GB - SSD 128 GB | Type | Personal computer - mini tower | Localisation | Region: United Kingdom | Processor | Intel Core i3 (7th Gen) 7100 / 3.9 GHz (Dual-Core) | Processor Socket | LGA1151 Socket | Cache Memory | 3 MB | Cache Per Processor | 3 MB | RAM | 4 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | SSD 128 GB | Optical Storage | DVD-Writer | Graphics Controller | Intel HD Graphics 630 | Audio Output | 5.1 channel surround | Networking | 1GbE | Power | AC 120/230 V | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 16.5 cm x 32 cm x 34 cm | Weight | 8 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - carry-in |
General | |
Type | Personal computer |
Product Form Factor | Mini tower |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i3 (7th Gen) 7100 |
Clock Speed | 3.9 GHz |
Number of Cores | Dual-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel H110 Express |
Cache Memory | |
Installed Size | 3 MB |
RAM | |
Installed Size | 4 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 128 GB |
Manufacturer | Kingston |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer - SATA |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, HDMI |
Audio Output | |
Sound Output Mode | 5.1 channel surround |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111H |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol | DMI |
Features | Wake on LAN (WoL), PXE support |
Expansion / Connectivity | |
Bays | 5.25" , 3.5" |
Slots | 1 (total) / 1 (free) x PCIe x16 |
Interfaces | 4 x USB 2.0 (2 front, 2 rear) , 2 x USB 3.1 Gen 1 (2 rear) , 1 x LAN (Gigabit Ethernet) , 2 x audio line-in/microphone (1 front, 1 rear) , 2 x audio line-out/headphones (1 front, 1 rear) , 1 x audio line-in , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x VGA , 1 x HDMI |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | VCCI, BSMI, GS, CB, FCC, RoHS, PC 2001, EuP |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V |
Power Provided | 220 Watt |
Efficiency | 82%+ |
Power Factor Correction | Yes (active) |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Dimensions & Weight | |
Width | 16.5 cm |
Depth | 32 cm |
Height | 34 cm |
Weight | 8 kg |
