Looking for a creative solution to your limited workspace? The compact Veriton N Series packs generous processing power, manageability and security features into a 1-liter design perfect for space-restricted settings.
Product Description | Acer Veriton N4 VN4640G - tiny - Core i5 7400T 2.4 GHz - 4 GB - HDD 500 GB | Type | Personal computer - tiny | Localisation | Region: United Kingdom | Processor | Intel Core i5 (7th Gen) 7400T / 2.4 GHz (, up to 3 GHz, (Quad-Core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 6 MB | Cache Per Processor | 6 MB | RAM | 4 GB (installed) / 16 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | HDD 500 GB - SATA 6Gb/s - 5400 rpm | Optical Storage | No optical drive | Graphics Controller | Intel HD Graphics 630 | Networking | 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.2 | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 24.95 cm x 20.4 cm x 5.95 cm | Weight | 1.5 kg |
General | |
Type | Personal computer |
Product Form Factor | Tiny |
Embedded Security | Trusted Platform Module (TPM 2.0) Security Chip |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7400T |
Clock Speed | 2.4 GHz |
Max Turbo Speed | 3 GHz |
Number of Cores | Quad-Core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel H110 Express |
Cache Memory | |
Installed Size | 6 MB |
RAM | |
Installed Size | 4 GB / 16 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) / 1 (empty) |
Configuration Features | 1 x 4 GB |
Hard Drive | |
Type | HDD |
Capacity | 1 x 500 GB |
Manufacturer | Seagate |
Interface Type | SATA 6Gb/s |
Spindle Speed | 5400 rpm |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel HD Graphics 630 |
Video Interfaces | VGA, DisplayPort |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek 8111EPV |
Wireless LAN Supported | Yes |
Wireless NIC | Intel Dual Band Wireless-AC 7265 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 |
Expansion / Connectivity | |
Slots | 1 PCIe x16 |
Interfaces | 4 x USB 3.0 (3 front, 1 rear) , 2 x USB 2.0 (2 rear) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x HDMI |
Miscellaneous | |
Included Accessories | Wireless antenna, VESA mounting kit |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Compliant Standards | VCCI, BSMI, GS, CB, FCC, RoHS, PC 2001 |
Power | |
Device Type | Power adapter |
Power Provided | 65 Watt |
Operating System / Software | |
Dimensions & Weight | |
Width | 24.95 cm |
Depth | 20.4 cm |
Height | 5.95 cm |
Weight | 1.5 kg |
