Form plus functionality is increased with a modern look, small form factor chassis, increased ventilation grills and a an elegant design.
Product Description | Acer Veriton X2 VX2660G - SFF - Core i5 8400 2.8 GHz - 8 GB - SSD 256 GB | Type | Personal computer - small form factor | Localisation | Region: United Kingdom | Processor | Intel Core i5 (8th Gen) 8400 / 2.8 GHz (, up to 4 GHz, (6-core) | Processor Socket | LGA1151 Socket | Processor Main Features | Intel Turbo Boost Technology 2 | Cache Memory | 9 MB | Cache Per Processor | 9 MB | RAM | 8 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA | Hard Drive | SSD 256 GB | Optical Storage | DVD-Writer | Card Reader | Yes | Graphics Controller | Intel UHD Graphics 630 | Audio Output | 5.1 channel surround | Networking | 1GbE | Power | AC 120/230 V | OS Provided | Windows 10 Pro 64-bit Edition | Dimensions (WxDxH) | 10.2 cm x 30.508 cm x 33 cm | Weight | 5 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | Limited warranty - 1 year - carry-in |
General | |
Type | Personal computer |
Product Form Factor | Small form factor |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8400 |
Clock Speed | 2.8 GHz |
Max Turbo Speed | 4 GHz |
Number of Cores | 6-core |
CPU Qty | 1 |
Max CPU Qty | 1 |
CPU Socket | LGA1151 Socket |
Chipset Type | Intel B360 |
Cache Memory | |
Installed Size | 9 MB |
RAM | |
Installed Size | 8 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | DIMM 288-pin |
Features | Unbuffered, dual channel memory architecture |
Configuration Features | 1 x 8 GB |
Hard Drive | |
Type | SSD |
Capacity | 1 x 256 GB |
Manufacturer | Kingston |
Storage Controller | |
Type | 1 x SATA |
Optical Storage | |
Type | DVD-Writer - SATA |
Card Reader | |
Type | Card reader |
Supported Flash Memory Cards | SD Memory Card |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | Intel UHD Graphics 630 |
Video Interfaces | VGA, HDMI, DisplayPort |
Audio Output | |
Sound Output Mode | 5.1 channel surround |
Compliant Standards | High Definition Audio |
Input Device | |
Type | Mouse, keyboard |
Keyboard | |
Interface | USB |
Mouse | |
Interface | USB |
Networking | |
Ethernet Controller | Realtek RTL8111 |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Remote Management Protocol | DMI |
Features | Wake on LAN (WoL), PXE support |
Expansion / Connectivity | |
Slots | 1 (total) / 1 (free) x PCIe x16 , 2 (total) / 2 (free) x PCIe x1 , 1 (total) / 1 (free) x PCI |
Interfaces | 1 x PS/2 keyboard , 1 x PS/2 mouse , 2 x audio line-out/headphones (1 front, 1 rear) , 2 x microphone (1 front, 1 rear) , 1 x audio line-in (1 rear) , 4 x USB 2.0 , 2 x USB 3.1 Gen 2 , 2 x USB 3.1 Gen 1 , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x HDMI , 1 x DisplayPort |
Miscellaneous | |
Included Accessories | 2.5" HDD metal bracket with toolless kit |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), chassis intrusion alarm |
Security Slot Type | Kensington security slot |
Compliant Standards | BSMI, CB, FCC, RoHS, EuP |
Power | |
Device Type | Power supply |
Voltage Required | AC 120/230 V |
Power Provided | 180 Watt |
Efficiency | 82%+ |
Power Factor Correction | Yes (active) |
Operating System / Software | |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year - carry-in |
Dimensions & Weight | |
Width | 10.2 cm |
Depth | 30.508 cm |
Height | 33 cm |
Weight | 5 kg |
