We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Meet Echo Flex
Plug it in and use your voice to access instant information, add to your shopping basket, check the weather, make hands-free calls and control compatible smart home devices.
Make any space a little smarter
From down the hallway to around the corner, Alexa is happy to help make your day a little brighter. Use your voice to set timers or create daily reminders. Check the news, weather or traffic. Ask for sports scores, film screening times or restaurant opening hours.
Voice control more of your home
Manage compatible smart home devices using your voice. Switch on the lamp before getting out of bed, turn on the coffee machine on your way to the kitchen, or dim the lights from the sofa to watch a film.
Keep your family in sync
Use Announcements to send voice messages to every room with a supported Echo device, or use Drop In as a two-way intercom between rooms. You can also make hands-free calls to almost anyone.
Alexa has skills
With tens of thousands of skills and counting, Alexa is always getting smarter. Skills are like apps and help you do more, such as play relaxing sounds or test your music knowledge. Just say, "Alexa, what are your top skills?"
Designed to protect your privacy
Alexa and Echo devices are built with multiple layers of privacy protection. For example, Echo Flex has a Microphone Off button that electronically disconnects the microphones. You also have control over your voice recordings. You can view, hear or delete them at any time.
Product Description | Amazon Echo Flex - smart speaker | Product Type | Smart speaker | Localisation | United Kingdom | Speaker Type | Active | Interfaces | Bluetooth, Wi-Fi | Intelligent Assistant | Alexa - direct | Speaker Details | Speaker - mono - active | Dimensions (WxDxH) | 6.7 cm x 6.6 cm x 7.2 cm | Weight | 166 g | Manufacturer Warranty | 1-year warranty |
General | |
Microphone | Yes |
Speaker System | |
Amplifier | Integrated |
Interfaces | Bluetooth, IEEE 802.11a/b/g/n/ac |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Type | Cloud |
Intelligent Assistant | Alexa |
Voice Control | Direct |
Speaker System Details | |
Driver Details | Full-range driver - 0.6" |
Connections | |
Connector Type | Audio line-in (mini-phone stereo 3.5 mm) , USB (4 PIN USB Type A) |
Power | |
Power Source | Integrated power supply |
Dimensions & Weight | |
Width | 6.7 cm |
Depth | 6.6 cm |
Height | 7.2 cm |
Weight | 166 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
