Anker PowerPort III Nano-20W Fast Charger for iPhone
new
UP TO 3× FASTER THAN AN ORIGINAL 5W CHARGER
£19.99
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • The power your iPhone needs
  • Fast charging
  • Compact and portable
  • One for all
  • Advanced charging technology
  • Device Type: Apple
  • Type: Charger
  • Product Range: Anker PowerPort, Anker
  • Product Model: III Nano
Product codes
chevron icon
chevron icon
Anker Nano iPhone Charger, 20W PIQ 3.0 Durable Compact Fast Charger, PowerPort III USB-C Charger for iPhone SE 2020/11/11 Pro Max, Galaxy, Pixel 4/3, iPad Pro, Nintendo Switch, AirPods Pro, and More
  • Designed for iPhone: Anker Nano’s 20W output is designed to provide the maximum charge to iPhone 8 or later.
  • Unrivaled Speed: Charge iPhone 11 and previous iPhone models up to 3× faster than with an original 5W Charger.
  • Space-Saving Design: At 50% smaller than a standard 18W iPhone charger, Anker Nano provides more power while saving space in your bag or while plugged into a wall outlet.
  • Works with Most Handheld Devices: Provide up to 20W charging to most flagship phones including iPhone and Samsung Galaxy S20 as well as smartwatches and earbuds.
Anker Nano (PowerPort III Nano)
The Super-Small 20W Charger for iPhone
Fast Charging
Charge iPhone 11 to 53% in just 30 minutes—that’s up to 3× faster than with an original 5W charger.
Compact and Portable
Measuring just over 1 inch on each side and weighing about the same as a AA battery, this is a high-speed charger with unrivaled power and portability.
One for All
Anker Nano is optimized to work flawlessly with a wide range of smartphones, tablets, and more, so now you can charge all of your mobile devices via a single ultra-portable charger.
Advanced Charging Technology
Anker’s latest technology uses a stacked design with custom magnetic components to reduce size, boost efficiency, and improve heat dissipation.
Compatibility
Lightning devices
  • USB-C to Lightning cable required (sold separately)
  • iPhone SE 2020 / 11 / 11 Pro / 11 Pro Max / XS / XS Max / XR / X / 8 Plus / 8 / 7 Plus / 7 / 6 Plus
  • iPad Pro 10.5; iPad Air 3 10.5"; iPad mini 5 7.9" and later models
  • AirPods, AirPods Pro, Apple Watch, and More
USB-C devices
  • USB-C to USB-C cable required (sold separately)
  • 2020 / 2018 iPad Pro 12.9’’ Gen 4 / 3, iPad Pro 11’’ Gen 2 / 1
  • Galaxy S20/ S20+/ S20 Ultra/ S10 / S10+ / S10e /S9 / S9+ / S8 /S8+
  • Note 20/ Note 20 Ultra/ Note 10+/ Note 10/ Note 9
  • Pixel 4/ 4XL/ 3a/ 3XL / 3 / 2 XL / 2, and More
Specs
  • Input: 100-240V 0.6A 50-60Hz
  • Output: 5V=3A/9V=2.22A
Note
  • Will charge Nintendo Switch but does not support "Charge-and-Play" in TV mode.
  • After connecting to iPhone (8 / 8 Plus / X / XS Max / XS / XR), fast charging (9V) will begin automatically, regardless of whether you hear one charging indicator sound or two.
  • This charger is compatible with Note 10 / Note 10+, but does not support full-speed fast charging.
  • Use a USB-C to Lightning cable for Lightning devices and use a USB-C to USB-C cable for USB-C devices (Cables sold separately).
chevron icon
Product Description Anker PowerPort III Nano power adapter - 24 pin USB-C - 20 Watt
Product Type Power adapter
Dimensions (WxDxH) 4.75 cm x 2.21 cm x 4.12 cm
Colour White
Output Connector Type 24 pin USB-C
Voltage Required AC 100-240 V (50 - 60 Hz)
Fast Charge Technology Anker PowerIQ 3.0
Power Provided 20 Watt
Manufacturer Warranty 18 months warranty
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£19.99
