The Need for Speed: With 10W high-speed charging for Samsung Galaxy, and a 7.5W charging mode to refuel iPhones. The fastest possible wireless input that each can accept.
Two is better: charge 2 devices at once with dual pads twin charging surfaces.
Case friendly: Don't worry about taking your case off whenever you have to charge. PowerWave chargers deliver power directly through cases up to 5mm thick - including Otterboxes.
Product Description | Anker PowerWave 10 Dual Pad wireless charging pad - + AC power adapter - 10 Watt | Product Type | Wireless charging pad + AC power adapter | Dimensions (WxDxH) | 20.46 cm x 9.2 cm x 1.48 cm | Weight | 185 g | Colour | White | Voltage Required | 12 V | Max Electric Current | 3 A | Wireless Charging Standards | Qi | Power Provided | 10 Watt | Manufacturer Warranty | 18 months warranty |
General | |
Designed For | Mobile phone |
Width | 20.46 cm |
Depth | 9.2 cm |
Height | 1.48 cm |
Weight | 185 g |
Enclosure Colour | White |
Power Device | |
Wireless Charging | Yes |
AC Power Adapter Included | Yes |
Features | LED indicator |
Manufacturer Warranty | |
Service & Support | Limited warranty - 18 months |
