Comfort, convenience, and performance in a 23.8" Full HD display with DisplayPort.
Product Description | AOC 24P2Q - LED monitor - Full HD (1080p) - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class E | Power Consumption (On mode) | 17.4 W | Features | USB 3.2 Gen 1 hub | Panel Type | IPS | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 at 75 Hz | Pixel Pitch | 0.2745 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 50000000:1 (dynamic) | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Colour Gamut | 107% sRGB, 79% Adobe RGB | Input Connectors | HDMI, DVI, DisplayPort, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Screen Coating | Anti-glare, 3H Hard Coating | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 54.02 cm x 20.1 cm x 51.3 cm | Weight | 4.63 kg | Environmental Standards | TCO Certified Displays 8 | Compliant Standards | RoHS, Lead-Free, Mercury-free | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.8" |
Built-in Devices | USB 3.2 Gen 1 hub |
Panel Type | IPS |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | WLED |
OSD Languages | Multilingual |
Features | Flicker Free technology, USB 3.0 Fast Charge |
Colour | Black |
Dimensions (WxDxH) | 54.02 cm x 20.1 cm x 51.3 cm - with stand |
Weight | 4.63 kg |
Audio | |
Type | Speakers - stereo |
Output Power / Channel | 2 Watt |
Connectivity | |
Interfaces | VGA (HD-15) , DVI , HDMI , DisplayPort 1.2 , 4 x USB 3.2 Gen 1 , Audio line-in , Headphones (mini-jack) |
Mechanical | |
Tilt Angle | -5/+35 |
Swivel Angle | 180 |
Height Adjustment | 150 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x HDMI cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x audio cable - 1.8 m , 1 x USB cable - 1.8 m |
Power | |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption SDR (On mode) | 17.4 kWh/1000h |
Power Consumption (Typical) | 20 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | Without stand - width: 54.02 cm - depth: 5.07 cm - height: 32.64 cm |
Environmental Standards | |
TCO Certified | TCO Certified Displays 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
