ITEM | QTY | PRICE |
Logitech Zone Wired MSFT Teams Headse...
2 | £262.86 |
Introducing AirPods Max — a perfect balance of exhilarating high-fidelity audio and the effortless magic of AirPods. The ultimate personal listening experience is here.
The over-ear headphone has been completely reimagined. From cushion to canopy, AirPods Max are designed for an uncompromising fit that creates the optimal acoustic seal for many different head shapes — fully immersing you in every sound.
AirPods Max combine high-fidelity audio with industry-leading Active Noise Cancellation to deliver an unparalleled listening experience. Each part of their custom-built driver works to produce sound with ultra-low distortion across the audible range. From deep, rich bass to accurate mids and crisp, clean highs, you’ll hear every note with a new sense of clarity.
With a powerful Apple-designed H1 chip in each cup, our custom acoustic design and advanced software, AirPods Max use computational audio to create a breakthrough listening experience. By tapping into each chip’s 10 audio cores, computational audio helps block outside noise, adapts audio to the fit and seal of your ear cushions, and makes movie scenes sound like they’re happening all around you.
Good to know
Product Description | Apple AirPods Max - headphones with mic | Product Type | Headphones - Bluetooth - wireless | Compatibility | iPhone, iPad, iPod, Mac | Recommended Use | Portable electronics, computer | Additional Functions | Wireless audio sharing, transparency mode, spatial audio with dynamic head tracking | Colour | Sky blue | Headphones Form Factor | Full size | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Headphones Technology | Dynamic | Bluetooth Version | Bluetooth 5.0 | Sound Output Mode | Stereo | Sound Effects | Adaptive EQ | Active Noise Canceling | Yes | Microphones Included | 9 | Controls | Volume, play/pause, next/previous track, voice assistant, answer call, ANC/transparency | Intelligent Assistant | Siri | Manufacturer Warranty | 1-year warranty |
General | |
Dimensions & Weight Details | Headphones: 16.86 cm x 8.34 cm x 18.73 cm / 384.8 g , Case: 134.5 g |
Width | 16.86 cm |
Depth | 8.34 cm |
Height | 18.73 cm |
Weight | 384.8 g |
Colour | Sky blue |
Body Material | Stainless steel, anodised aluminium |
Headband Material | Knit mesh |
Earpad Material | Memory foam, mesh textile |
Features | On-ear detection |
Audio Output | |
Magnet Material | Neodymium magnet |
Adjustable Headband | Yes |
Features | Apple H1 chip |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Tracking | |
Sensors | Accelerometer, gyro sensor, position sensor, optical sensor, case-detect sensor |
Internet of Things (IoT) | |
Miscellaneous | |
Included Accessories | Charging case, Lightning to USB-C cable |
Cable Details | USB-C to Lightning cable - detachable |
Power | |
Battery | Headphone battery rechargeable |
Run Time (Up To) | 20 hour(s) |
Run Time Details | Continuous playback (active noise-cancelling on): up to 20 hours , Continuous playback (spatial audio on): up to 20 hours , Continuous talk: up to 20 hours |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
