The MagSafe Duo Charger conveniently charges your compatible iPhone, Apple Watch, Wireless Charging Case for AirPods, and other Qi-certified devices. Just place your devices on the charger and a steady, efficient charge begins on contact. The charger folds together neatly so you can easily take it with you wherever you go.
Product Description | Apple MagSafe Duo Charger wireless charging mat - magnetic | Product Type | Wireless charging mat | Output Connector Type | Total 2: magnetic | Wireless Charging | Yes | Wireless Charging Standards | Qi | Cables | USB-C to Lightning cable - 1 m | Manufacturer Warranty | 1-year warranty |
General | |
Designed For | Mobile phone, smart watch, wireless earphones |
Power Device | |
Input Connectors | 24 pin USB-C |
Output connectors | Total 2: magnetic |
Miscellaneous | |
Cables Included | USB-C to Lightning cable - 1 m |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
