Our most powerful floodlight camera
The first 100% wire-free floodlight camera illuminates the most vulnerable parts of your property. A motion-activated light more powerful than a car headlight deters intruders before they even get close to your property. While 2K video captures all the important details for the best possible protection.
Wire-Free Security Installed in Minutes.
Easily mounts in multiple locations for protection from every angle.
Never be left in the dark
Light up your property with 2000-3000 lumens.
Color Night Vision
See video in full color or traditional black and white.
2K HDR
Zoom in on objects and capture clearer details and colors.
160° Viewing Angle
Keep an eye on what matters with a wide 160° diagonal field of view.
2-Way Audio
Hear and speak to visitors clearly with superior audio quality.
Built-in Smart Siren
Trigger your siren automatically, or manually from the Arlo app.
Weather-resistant design
Built to withstand heat, cold, rain or sun.
Custom control
Easily adjust brightness, video, and audio settings to your preference.
Rechargeable battery
Go wire-free with a convenient and long-lasting battery.
Multiple power options
Keep your floodlight camera charged all day with an optional Solar Panel or Outdoor Charging Cable (sold separately).
3-month Arlo Smart trial included
Personalized notifications keep you informed of events that matter so you can take quick action—from phoning a friend to sound an alarm, or calling emergency services.
What's included:
(1) Arlo Pro 3 Floodlight Camera
(1) XL Rechargeable Battery
(1) Power Adapter
(1) Micro-USB Cable
(1) Wall Plate and Screw Kit
(1) Quick Start Guide
(1) Video Monitoring Decal
Product Description | Arlo Pro 3 Floodlight Camera - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: two-way audio capability, built-in microphone | Camera Mount Type | Wall mount | Dimensions (WxDxH) | 21.852 cm x 19.05 cm x 7.793 cm | Weight | 650 g | Colour | Black | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Max Resolution | 2560 x 1440 | Video Modes | 720p, 1080p, 2K | Optical Sensor Type | 1/3" - 4 MP | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Cables Included | 1 - micro-USB cable - external | Features | High Dynamic Range (HDR), built-in siren, Colour Night Vision, built-in spotlight | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20 °C - 45 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: two-way audio capability, built-in microphone |
Width | 21.852 cm |
Depth | 19.05 cm |
Height | 7.793 cm |
Weight | 650 g |
Localisation | Europe |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Digital Video Format | H.264, H.265 |
Max Digital Video Resolution | 2560 x 1440 |
Digital Zoom | 12 |
Image Sensor | |
Type | 4 MP 1/3" |
Lens Construction | |
Horizontal Field of View (degree) | 160 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Miscellaneous | |
Included Accessories | Wall mount kit, screw kit, rechargeable battery, video monitoring decal |
Cables Included | 1 x micro-USB cable - external |
Colour | Black |
Power | |
Power Device | Power adapter - external AC 100 - 240 V |
Battery | 1 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Dimensions & Weight (Shipping) | |
Shipping Width | 24.5 cm |
Shipping Depth | 19.8 cm |
Shipping Height | 13.4 cm |
Shipping Weight | 1.362 kg |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
