Enjoy the peace of mind that comes from knowing your home is safe and secure. Built with advanced 4K resolution and a wider field of view, Arlo Ultra 2 provides powerful, wire-free security to protect your loved ones.
4K Video with HDR:
Zoom in up to 12x to see sharp details with Arlo Ultra’s 4K & HDR advanced image quality technology.
Enhanced night vision:
Color night vision lets you see key details even in the dark
180 degree diagonal field of view:
See more with a wider angle lens that has auto image correction reducing the fish eye effect.
Integrated spotlight:
Scare off unwelcome guests using Arlo Ultra’s motion-activated spotlight.
Weather-resistant
Built to withstand heat, cold, rain or sun.
Versatile magnetic charging.
The magnetic charging cable snaps into place for continuous power all day.
100% wire-free with 6-month battery life
100% wire-free with 6-month battery life on one charge you can easily install your camera to watch over the most vulnerable parts of your property.
Premium 2-way Audio:
Listen and speak to visitors with crystal clear, full 2-way audio that reduces wind and noise
Built-in smart siren:
Trigger the siren from the Arlo app or have it sound automatically when motion is detected to scare away intruders.
Product Description | Arlo Ultra 2 Security System - gateway + camera(s) - wireless (802.11b, 802.11g, 802.11n, 802.11ac, Bluetooth 4.2 LE) - battery powered, AC powered | System | Gateway + camera(s) - wireless - IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 LE - battery, power adapter | Camera | 4 cameras - outdoor - night vision | Platform | Apple HomeKit, SmartThings | Intelligent Assistant | Google Assistant, Alexa | Localisation | Europe | Manufacturer Warranty | 1 year |
General | |
System | Gateway + camera(s) - wireless |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.2 LE |
Features | Built-in microphone, built-in speaker, auto focus, motion alerts, upload to cloud, microSD card slot, infrared cut filter, motion detection, weather-resistant, Smart Siren, colour night vision, 4K Ultra HD video, High Dynamic Range (HDR), two-way audio support, spotlight, 12x digital zoom, movement tracking, up to 6 months battery lifetime |
Package Content | 4 cameras, camera wall mount, power adapter, magnetic charging cable, video monitoring decal, SmartHub, 4 rechargeable batteries, screw kit |
Cables Included | Network cable - 1 pcs. |
Power Source | Battery, power adapter |
Compliant Standards | IC, FCC, AES-128, 128-bit SSL, REACH, EU RoHS, WERCS, EuP1275 |
Warranty | 1 year |
Cameras | |
Quantity | 4 cameras |
Camera Type | Outdoor |
Sensor | 1/2" - 3840x2160 |
Field of View | 151° (H), 80° (V), 180° (D) |
Night Vision | Yes |
Infrared LEDs | Yes |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 45 °C |
Compliant Standards | IP65 |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Compatible Services | IFTTT |
Dimensions & Weight | |
Details | Camera: 5.2 cm x 8.9 cm x 7.84 cm - 331 g , Gateway: 14 cm x 5.24 cm x 15.3 cm - 300 g |
