The ASUS VivoBook Max laptops are designed to give you a truly immersive multimedia experience. Powered by a fast processor, gaming-grade graphics, and SonicMaster audio, incorporating ICEpower technology, the VivoBook Max gives you outstanding audiovisuals.
Product Description | ASUS VivoBook Max X541UA GO799T - 15.6" - Intel Core i7 - 7500U - 8 GB RAM - 1 TB HDD | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i7 (7th Gen) - 7500U / 2.7 GHz, up to 3.5 GHz / 4 MB Cache | Memory | 8 GB DDR4 (provided memory is soldered) | Storage | 1 TB HDD / 5400 rpm | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 620 | Integrated Webcam | Yes | Networking | 802.11b/g/n, Bluetooth 4.0, 10/100 Ethernet | Battery | 3-cell | Colour | Chocolate black IMR with hairline (LCD cover), gold IMR with hairline (top) | Dimensions (WxDxH) | 38.14 cm x 25.15 cm x 2.76 cm | Weight | 2 kg |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (7th Gen) 7500U / 2.7 GHz |
Max Turbo Speed | 3.5 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0, Intel Smart Cache |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Empty Slots | 1 |
Storage | |
Main Storage | 1 TB HDD SATA 3Gb/s / 5400 rpm |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Colour Gamut | 45% NTSC |
Features | ASUS Splendid Video Intelligence Technology, glare, ASUS EyeCare Technology, Tru2Life |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - VGA |
Sound | Stereo speakers, microphone |
Audio Features | Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower, ASUS AudioWizard |
Input | |
Type | Keyboard, touchpad |
Features | ASUS Smart Gesture technology |
Communications | |
Wireless | 802.11b/g/n, Bluetooth 4.0 |
Network Interface | 10/100 Ethernet |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 36 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V, 2.37 A |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , USB 3.0 , VGA , USB 2.0 , HDMI , LAN , USB-C 3.1 Gen 1 |
Memory Card Reader | Yes (SD Card, SDHC Card, SDXC Card) |
Miscellaneous | |
Features | System password, hard drive password, ASUS SuperBatt Technology |
Included Accessories | Power adapter |
Dimensions & Weight | |
Weight | 2 kg |
Sustainability Information | |
TCO Certified | - |
