LED-backlit provides you up to three illumination modes that can be customized via an intuitive interface. You can also create macros and shortcuts for all keys. Cerberus keyboard MKII lets you program up to 12 macros for complex in-game actions or commands.
Product Description | ASUS CERBERUS MKII - keyboard - UK - black Input Device | Device Type | Keyboard | Backlit | Multicolour | Interface | USB | Connectivity Technology | Wired | Localization and Layout | UK | Hot Keys Function | Volume, macros buttons, play/pause, stop, previous track, next track, Windows key lock | Numeric Keypad | Yes | Colour | Black | Dimensions (WxDxH) | 47.1 cm x 18.6 cm x 4.1 cm | Weight | 1.1 kg |
General | |
Interface | USB |
Keyboard Technology | Membrane |
Simultaneous Key Press Quantity | 19 |
Features | Numeric keypad |
Width | 47.1 cm |
Depth | 18.6 cm |
Height | 4.1 cm |
Weight | 1.1 kg |
Miscellaneous | |
Colour | Black |
Cable Length | 2 m |
Included Accessories | Replaceable red WASD keys |
Compliant Standards | SECC |
Software & System Requirements | |
OS Required | Microsoft Windows XP/ 7 / 8 / 8.1 / 10 |
