Solid reliability for your business
ASUS Mini PC PB60G is a compact workstation mini PC that features a stackable, modular design to deliver powerful customizability for professional usage. High-end NVIDIA® Quadro® P620 or Quadro® P1000 graphics combined with ISV certification makes Mini PC PB60G a perfect choice for 2D and 3D CAD applications. HDMI, DisplayPort and four mini DisplayPort outputs support up to seven displays for professionals who work with lots of visual information. ASUS Mini PC PB60G is also part of the ASUS Corporate Stable Model program, providing businesses with extensive support for long-term use and worry-free maintenance.
Workstation-grade performance, slim style
Powered by the 8th Gen Intel® Core™ Processors, ASUS Mini PC PB60G increases performance by up to 30% compared to previous generation processors for smoother handling of intensive computing tasks. Up to 32GB of fast DDR4 2400MHz memory boosts performance even further for improved multitasking, and a dual-storage design with one M.2 PCIe 3.0 x4 SSD and one 2.5-inch HDD provides the perfect mix of fast data transfers and high storage capacity.
Powerful NVIDIA® Quadro® graphics
ASUS Mini PC PB60G comes with a graphics module featuring an NVIDIA® Quadro® P620 or Quadro® P1000 graphics card to deliver fast, high-power performance when working with 2D or 3D models. Combined with support for up to seven 4K HDR displays that give you an expansive visual workspace to view your creations in stunning detail, Mini PC PB60G is the perfect tool for fields involving complex design tasks, such as media and entertainment, manufacturing, engineering and architecture.
Independent software vendor (ISV) certification
Independent software vendor (ISV) software is becoming an important factor to users in variety of industries. ASUS works in close partnership with ISV vendors, such as Adobe and Autodesk, to test and verify compatibility. This ensures ASUS Mini PC are reliable and highly effective for users in different fields.
High-speed data performance and large storage capacities
ASUS Mini PC PB60G supports Intel® Optane™, a smart and adaptable memory* technology that accelerates system performance and responsiveness, enabling up to 24X faster HDD access speeds, 19% faster daily computing performance, and 2.1X faster file searches. A high-capacity HDD, coupled with Intel® Optane™ memory, provides the optimal combination of large storage and incredibly fast data access.
Versatile, space-saving design
ASUS Mini PC PB60G has a stylish metal case that measures just 17.5 x 17.5 x 7cm, so it takes up very little room to help you maintain a clutter-free workspace. It can also be mounted easily to the back of any VESA-compatible display, making it perfect for a range of business applications — from a media server to a store kiosk.
Stackable, modular design for added functionality
ASUS Mini PC PB60G features a stackable, modular design with a choice of optional components, such as optical drive, that give you customized functionality to meet your specific needs.
Product Description | ASUS Mini PC PB60G B5024ZD - mini PC - Core i5 8400T 1.7 GHz - 16 GB - SSD 256 GB, HDD 1 TB | Type | Workstation - mini PC | Processor | 1 x Intel Core i5 (8th Gen) 8400T / 1.7 GHz (3.3 GHz) (6-core) | RAM | 16 GB (installed) / 32 GB (max) - DDR4 SDRAM | Storage Controller | SATA (SATA 6Gb/s) | Hard Drive | SSD 256 GB | Hard Drive (2nd) | HDD 1 TB - SATA | Optical Storage | No optical drive | Graphics Controller | NVIDIA Quadro P620 | Video Memory | 2 GB GDDR5 SDRAM | Networking | GigE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 5.0 | OS Provided | Windows 10 Pro | Colour | Black | Dimensions (WxDxH) | 17.5 cm x 17.5 cm x 7.02 cm | Weight | 1.59 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Type | Workstation |
Product Form Factor | Mini PC |
Colour | Black |
Processor / Chipset | |
CPU | Intel Core i5 (8th Gen) 8400T |
Clock Speed | 1.7 GHz |
Max Turbo Speed | 3.3 GHz |
Number of Cores | 6-core |
CPU Qty | 1 |
Max CPU Qty | 1 |
Chipset Type | Intel B360 |
RAM | |
Installed Size | 16 GB / 32 GB (max) |
Technology | DDR4 SDRAM |
Effective Memory Speed | 2400 MHz |
Rated Memory Speed | 2400 MHz |
Form Factor | SO-DIMM 260-pin |
Slots | 2 (Total) |
Hard Drive | |
Type | SSD |
Capacity | 1 x 256 GB |
Hard Drive (2nd) | |
Type | HDD |
Interface Class | Serial ATA |
Capacity | 1 x 1 TB |
Storage Controller | |
Type | 1 x SATA |
Controller Interface Type | SATA 6Gb/s |
Optical Storage | |
Type | No optical drive |
Monitor | |
Monitor Type | None. |
Graphics Controller | |
Graphics Processor | NVIDIA Quadro P620 |
Networking | |
Wireless LAN Supported | Yes |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.0 |
Compliant Standards | Wi-Fi CERTIFIED |
Expansion / Connectivity | |
Interfaces | 2 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 3 x USB 3.1 Gen 2 (2 front, 1 rear) , 2 x USB 3.1 Gen 1 (2 in front) (one of them is fast-charging) , 1 x USB-C 3.1 Gen 1 (1 in front) , 2 x USB 2.0 (2 rear) , 4 x Mini DisplayPort |
Miscellaneous | |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately), chassis intrusion alarm |
Security Slot Type | Kensington security slot |
VESA Mounting Interface | Yes |
Compliant Standards | UL, VCCI, C-Tick, BSMI, CB, CCC, FCC |
Power | |
Device Type | Power adapter |
Power Provided | 120 Watt |
Operating System / Software | |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Width | 17.5 cm |
Depth | 17.5 cm |
Height | 7.02 cm |
Weight | 1.59 kg |
