To give you the maximum advantage in combat, Strix SCAR II features a narrow-bezel display with a fast response time - a must-have for hardcore gamers and e-sports players.
Product Description | ASUS ROG Strix SCAR II GL504GW ES012T - 15.6" - Intel Core i7 - 8750H - 16 GB RAM - 256 GB SSD + 1 TB Hybrid Drive | Product Type | Notebook | Operating System | Win 10 Home 64-bit | Processor | Intel Core i7 (8th Gen) - 8750H / 2.2 GHz, up to 4.1 GHz | Memory | 16 GB DDR4 (2 x 8 GB) | Storage | 256 GB SSD - NVMe + 1 TB Hybrid Drive / 5400 rpm | Display | 15.6" LED backlight 1920 x 1080 / Full HD @ 144 Hz | Graphics | NVIDIA GeForce RTX 2070 / Intel UHD Graphics 630 | Video Memory | 8 GB GDDR6 SDRAM | Gaming | Yes | Keyboard Backlight | Yes (RGB) | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0, Gigabit Ethernet | Battery | 4-cell | Colour | Black, gun metal | Dimensions (WxDxH) | 36.1 cm x 26.2 cm x 2.61 cm | Weight | 2.4 kg |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8750H / 2.2 GHz |
Max Turbo Speed | 4.1 GHz |
Number of Cores | 6-core |
64-bit Computing | Yes |
Chipset | Mobile Intel HM370 |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 16 GB (2 x 8 GB) |
Max RAM Supported | 32 GB |
Technology | DDR4 SDRAM |
Speed | 2666 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 256 GB SSD M.2 PCIe - NVM Express (NVMe) |
Secondary Storage | 1 TB Hybrid Drive SATA / 5400 rpm - Seagate |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
V-Sync Rate at Max Res. | 144 Hz |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Colour Gamut | 100% sRGB, 72% NTSC, 75.35% Adobe RGB |
Features | Anti-glare, 3 ms response rate |
Audio & Video | |
Multi-GPU Configuration | 1 single GPU card / integrated GPU |
Graphics Processor | NVIDIA GeForce RTX 2070 / Intel UHD Graphics 630 |
Video System Features | NVIDIA Optimus |
Gaming | Yes |
Camera | Yes - 720p |
Sound | Stereo speakers, array microphone |
Input | |
Type | Keyboard, touchpad |
Features | 4 RGB zones |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | 4-cell Lithium Ion |
Capacity | 66 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 230 Watt, 19.5 V, 11.8 A |
Connections & Expansion | |
Interfaces Details | USB-C 3.1 Gen 2 , 2 x USB 3.1 Gen 1 , USB 3.1 Gen 2 , Mini DisplayPort , HDMI , Headphone/microphone combo jack , LAN |
Memory Card Reader | Yes (SD Card) |
Miscellaneous | |
Features | System password |
Theft/Intrusion Protection | Security lock slot (cable lock sold separately) |
Security Slot Type | Kensington security slot |
Included Accessories | Power adapter, palm rest label, 3D ROG sculpture |
Dimensions & Weight | |
Weight | 2.4 kg |
Sustainability Information | |
TCO Certified | - |
