The ASUS Transformer was designed with one purpose in mind: to give you performance you never thought possible in a detachable 2-in-1 device. It's unbelievably powerful, amazingly convenient - and also incredibly expandable.
Product Description | ASUS Transformer Pro T304UA BC003R - 12.5" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD | Product Type | Tablet - with detachable keyboard | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB LPDDR3 (provided memory is soldered) | Storage | 256 GB SSD | Display | 12.5" LED backlight touchscreen 2160 x 1440 / Full HD Plus | Graphics | Intel HD Graphics 620 | Input Device | Keyboard, touchpad | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 2-cell | Dockable | Yes | Colour | Grey | Dimensions (WxDxH) - tablet | 29.9 cm x 21.1 cm x 0.885 cm | Weight | 850 g | Environmental Standards | - EPEAT Climate+ |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 1866 MHz |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 12.5" |
LCD Backlight Technology | LED backlight |
Touchscreen | Yes |
Resolution | 2160 x 1440 (Full HD Plus) |
Widescreen | Yes |
Image Aspect Ratio | 3:2 |
Image Brightness | 250 cd/m² |
Colour Gamut | 72% NTSC |
Features | ASUS Splendid Video Intelligence Technology, glare, ASUS EyeCare Technology, Tru2Life |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes |
Resolution | 8 Megapixel (rear), 2 Megapixel (front) |
Sound | Harman/kardon stereo speakers, microphone |
Audio Features | Output: ASUS Bang & Olufsen ICEpower, ASUS SonicMaster Premium |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Battery | |
Technology | 2-cell lithium polymer |
Capacity | 39 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V, 2.37 A |
Connections & Expansion | |
Interfaces Details | USB 3.0 , Headphone/microphone combo jack , HDMI , USB-C Gen 1 , Dock |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Colour | Grey |
Case Material | Metal |
Dockable | Yes |
Included Accessories | Stylus, power adapter, keyboard |
Dimensions & Weight | |
Weight | 850 g |
Sustainability Information | |
TCO Certified | - |
EPEAT Compliant | EPEAT Climate+ |
