The ASUS VivoBook E12 is designed to help you be productive all day - even when you're on the move. This compact and lightweight 11.6-inch laptop is powered by the advanced processor and provides long hours of battery life. It's an excellent laptop for people on the go.
Product Description | ASUS VivoBook E12 E203NA FD020TS - 11.6" - Intel Celeron - N3350 - 2 GB RAM - 32 GB eMMC | Product Type | Notebook - 180-degree hinge design | Operating System | Win 10 Home 64-bit | Processor | Intel Celeron N3350 / 1.1 GHz, up to 2.4 GHz / 2 MB Cache | Memory | 2 GB DDR3 (provided memory is soldered) | Storage | 32 GB eMMC | Display | 11.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics 500 | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 2-cell | Security | Firmware Trusted Platform Module (TPM) Security Chip | Colour | Pearl white | Dimensions (WxDxH) | 28.6 cm x 19.33 cm x 1.69 cm | Weight | 980 g | Specific Absorption Rate (SAR) | 0.075 W/kg (body) , 0.075 W/kg (limb) | Manufacturer Warranty | Limited warranty - 1 year |
General | |
Operating System | Windows 10 Home 64-bit Edition |
Processor / Chipset | |
CPU | Intel Celeron N3350 / 1.1 GHz |
Max Turbo Speed | 2.4 GHz |
Number of Cores | Dual-Core |
Cache | 2 MB |
64-bit Computing | Yes |
Memory | |
RAM | 2 GB (provided memory is soldered) |
Technology | DDR3 SDRAM |
Storage | |
Main Storage | 32 GB eMMC |
Display | |
Type | 11.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Colour Gamut | 45% NTSC |
Features | ASUS Splendid Video Intelligence Technology, glare, Tru2Life |
Audio & Video | |
Graphics Processor | Intel HD Graphics 500 |
Camera | Yes - VGA |
Sound | Stereo speakers, microphone |
Audio Features | Output: ASUS SonicMaster, ASUS Bang & Olufsen ICEpower |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Battery | |
Technology | 2-cell lithium polymer |
Capacity | 38 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 33 Watt, 19 V, 1.75 A |
Connections & Expansion | |
Interfaces Details | Headphone/microphone combo jack , 2 x USB 3.1 , USB-C 3.1 Gen 1 , HDMI |
Memory Card Reader | Yes (microSDXC) |
Miscellaneous | |
Case Material | Plastic |
Included Accessories | Power adapter |
SAR Value | 0.075 W/kg (body), 0.075 W/kg (limb) |
Dimensions & Weight | |
Weight | 980 g |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
