The E406 is designed to help you be productive all day - even when you're on the move. This compact and lightweight 14-inch laptop is powered by a high-performance processor and provides a long battery life. And with a NanoEdge display for immersive viewing, it's a great laptop for people on the go.
Product Description | ASUS E406MA BV009TS - 14" - Intel Celeron - N4000 - 4 GB RAM - 64 GB eMMC | Product Type | Notebook | Operating System | Windows 10 Home 64-bit in S mode | Processor | Intel Celeron N4000 / 1.1 GHz (2.6 GHz) / 4 MB Cache | Memory | 4 GB LPDDR4 (provided memory is soldered) | Storage | 64 GB eMMC | Display | 14" LED backlight 1366 x 768 / HD | Graphics | Intel UHD Graphics 600 | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 3-cell | Colour | Star grey IMR (LCD cover), starry grey painting (top) | Dimensions (WxDxH) | 32.64 cm x 22.65 cm x 1.76 cm | Weight | 1.3 kg | Environmental Standards | ENERGY STAR Qualified | SAR | 0.576 W/kg (body), 0.576 W/kg (limb) |
General | |
Operating System | Windows 10 Home 64-bit Edition in S mode |
Processor / Chipset | |
CPU | Intel Celeron N4000 / 1.1 GHz |
Max Turbo Speed | 2.6 GHz |
Number of Cores | Dual-Core |
Cache | 4 MB |
64-bit Computing | Yes |
Memory | |
RAM | 4 GB (provided memory is soldered) |
Technology | LPDDR4 SDRAM |
Storage | |
Main Storage | 64 GB eMMC |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 200 cd/m² |
Colour Gamut | 45% NTSC |
Features | Anti-glare, ASUS EyeCare Technology, Tru2Life, NanoEdge display |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 600 |
Camera | Yes - VGA |
Sound | Stereo speakers, microphone |
Audio Features | Output: ASUS SonicMaster, ASUS AudioWizard |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 56 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 33 Watt, 19 V, 1.75 A |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , 2 x USB 3.1 Gen 1 , HDMI |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Features | ASUS IceCool design |
Included Accessories | Power adapter |
Compliant Standards | UL, TUV, C-Tick, BSMI, CB, CCC, A-Tick, ErP 2013 |
SAR Value | 0.576 W/kg (body), 0.576 W/kg (limb) |
Dimensions & Weight | |
Weight | 1.3 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
