The ZENBOOK UX310 brings you elegance, sophistication and superb performance in a gorgeously slim and light design. Crafted from solid aluminum and featuring spun-metal Zen-inspired finish, ZENBOOK UX310 is extremely thin. And its travel-friendly weight means taking it with you is never a burden, and using it is always a pleasure with its crisp, clear 13.3-inch wide viewing angle display. Featuring a powerful processor, super-fast storage, ZENBOOK UX310 is no slouch, either - it has all the performance you need to blitz through your working day. ZENBOOK UX310 makes everything easier, in style.
Product Description | ASUS ZenBook UX310UA FC336R - 13.3" - Intel Core i5 - 7200U - 8 GB RAM - 256 GB SSD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i5 (7th Gen) - 7200U / 2.5 GHz, up to 3.1 GHz / 3 MB Cache | Memory | 8 GB DDR4 | Storage | 256 GB SSD | Display | 13.3" LED backlight 1920 x 1080 / Full HD | Graphics | Intel HD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 4.1 | Battery | 3-cell | Colour | Quartz grey | Dimensions (WxDxH) | 32.3 cm x 22.3 cm x 1.835 cm | Weight | 1.4 kg | Manufacturer Warranty | Limited warranty - 3 years - on-site |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (7th Gen) 7200U / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | 3 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 8 GB |
Max RAM Supported | 16 GB |
Technology | DDR4 SDRAM |
Speed | 2133 MHz |
Form Factor | SO-DIMM 260-pin |
Slots Qty | 1 |
Storage | |
Main Storage | 256 GB SSD M.2 SATA 6Gb/s |
Display | |
Type | 13.3" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 350 cd/m² |
Colour Gamut | 72% NTSC |
Features | ASUS Splendid Video Intelligence Technology, anti-glare, WideView |
Audio & Video | |
Graphics Processor | Intel HD Graphics 620 |
Camera | Yes - HD |
Sound | Harman/kardon stereo speakers, microphone |
Audio Features | Output: ASUS SonicMaster |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 4.1 |
Battery | |
Technology | 3-cell |
Capacity | 48 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V |
Connections & Expansion | |
Interfaces Details | USB-C 3.1 Gen 1 , 2 x USB 2.0 , USB 3.1 Gen 1 , Headphone/microphone combo jack , HDMI |
Memory Card Reader | Yes (SD Card, SDHC Card) |
Miscellaneous | |
Features | System password |
Included Accessories | Power adapter, sleeve |
Dimensions & Weight | |
Weight | 1.4 kg |
Sustainability Information | |
TCO Certified | - |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - on-site |
