Creativity. Style. Innovation. These are the qualities that define the elegant ZenBook 14. Everything in this take-anywhere masterpiece is designed to give you the freedom to discover your creative power, including its breathtaking frameless NanoEdge display. You'll appreciate not only the tremendous power within and the thoughtful attention to detail but also the timeless beauty of the design.
Product Description | ASUS ZenBook 14 UX433FA-A5179R - 14" - Core i7 8565U - 16 GB RAM - 512 GB SSD | Product Type | Notebook | Operating System | Win 10 Pro 64-bit | Processor | Intel Core i7 (8th Gen) 8565U / 1.8 GHz (4.6 GHz) / 8 MB Cache | Memory | 16 GB LPDDR3 (provided memory is soldered) | Storage | 512 GB SSD - NVMe | Display | 14" LED backlight 1920 x 1080 / Full HD | Graphics | Intel UHD Graphics 620 | Keyboard Backlight | Yes | Integrated Webcam | Yes | Networking | 802.11a/b/g/n/ac, Bluetooth 5.0, Ethernet | Battery | 3-cell | Security | Firmware Trusted Platform Module (TPM) Security Chip | Colour | Royal blue metal | Dimensions (WxDxH) | 31.9 cm x 19.9 cm x 1.59 cm | Weight | 1.09 kg |
General | |
Operating System | Windows 10 Pro 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i7 (8th Gen) 8565U / 1.8 GHz |
Max Turbo Speed | 4.6 GHz |
Number of Cores | Quad-Core |
Cache | 8 MB |
64-bit Computing | Yes |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 16 GB (provided memory is soldered) |
Technology | LPDDR3 SDRAM |
Speed | 2133 MHz |
Storage | |
Main Storage | 512 GB SSD M.2 PCIe - NVM Express (NVMe) |
Display | |
Type | 14" |
LCD Backlight Technology | LED backlight |
Resolution | 1920 x 1080 (Full HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Image Brightness | 300 cd/m² |
Colour Gamut | 72% NTSC |
Features | Ultra Slim Design, ASUS Splendid Video Intelligence Technology, anti-glare, 178° horizontal and vertical viewing angle, NanoEdge display |
Audio & Video | |
Graphics Processor | Intel UHD Graphics 620 |
Camera | Yes - HD |
Camera Features | IR/RGB camera |
Sound | Harman/kardon stereo speakers, array microphone |
Input | |
Type | Keyboard, touchpad |
Communications | |
Wireless | 802.11a/b/g/n/ac, Bluetooth 5.0 |
Network Interface | Ethernet |
Battery | |
Technology | 3-cell Lithium Ion |
Capacity | 50 Wh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 45 Watt, 19 V, 2.37 A |
Connections & Expansion | |
Interfaces | Headphone/microphone combo jack , USB-C 3.1 Gen 2 , USB 3.1 Gen 1 , HDMI , USB 2.0 , LAN (on supplied cable) |
Memory Card Reader | Yes (microSD) |
Miscellaneous | |
Features | ErgoLift |
Included Accessories | Power adapter, sleeve, USB 3.0 to Ethernet adapter |
Dimensions & Weight | |
Weight | 1.09 kg |
