120° Wide View Dual Rear Cameras, 5000mAh Battery
ASUS ZenFone 4 Max is a smartphone designed to go the distance and accompany you on all of life’s adventures. Its high capacity 5000mAh battery with advanced power management and dual cameras keeps up with your active lifestyle and is always at the ready to capture extraordinary moments.
Dual Rear Cameras - See a bigger world
ZenFone 4 Max features an advanced dual-camera system designed to take your mobile photography to new heights. Its 13MP main camera is equipped with the wide, F2.0 aperture lens to capture clearer photos. Its 120° wide-angle camera lets your fit more scenery and people in the frame for dramatic landscape shots, better group photos, and a more convenient photography experience in confined indoor spaces.
Wide-Angle Camera - Fit more scenery and friends in the shot
The 120° wide-angle camera on ZenFone 4 Max has a 200% larger field of view than standard smartphone cameras, so you can fit more scenery and people in the frame for dramatic photos and videos that capture a true sense of place. When taking photos indoors, the wide-angle view makes it much easier to get the shot you want — especially in confined spaces where it may not be possible to take a few steps back to fit everyone and everything into the photo. The unique perspective of the wide-angle lens can also be used to stylistic effect, allowing you to exaggerate the sense of space in any setting to capture more dramatic scenes and stunning, expansive landscapes.
PixelMaster Camera - Capture your world in detail
ZenFone 4 Max comes with a 13MP PixelMaster rear camera to capture beautiful, high-resolution photos with zero shutter lag. An 8MP front camera takes gorgeous, sharp selfies and lets you enjoy video chatting in with crystal-clear video clarity.
Front Camera - Capture the perfect selfie
ZenFone 4 Max combines an 8MP front camera with a Softlight LED flash and live beautification features to capture stunning selfies with ease. The Softlight LED flash delivers the perfect amount of fill light, giving your selfies a softer look with true skin tones and a glowing complexion. Beauty mode instantly retouches your selfies, removing blemishes, balancing facial features, and more to create a flawless look.
Beauty Mode - More beautiful, more fun, more you
The fun and intuitive Beauty mode lets you apply a variety of enhancement effects to your selfies to make them even more glamorous. With ten levels of beautification to choose from, you can smooth wrinkles, remove blemishes, adjust skin tone, and enhance your features instantly. Whether you are taking photos, capturing a video, or live streaming, ZenFone 4 Max lets you create your perfect look for the camera.
ASUS PowerMaster™ - A smarter smartphone battery
ZenFone 4 Max features a suite of intelligent power management technologies that work in concert to optimize battery life, ensure safety and long-term performance, provide reverse-charging capability, and more. By turning on the double battery lifespan feature, it means your device can fully charge (to 100%) and discharge (to 0%) up to 500 times in a 25°C environment, and the loss of battery capacity will be reduced by half.
High capacity, 5000mAh battery
Inside the sleek exterior of ZenFone 4 Max lies massive energy — a 5000mAh battery custom-crafted to pack maximum performance into minimum space. With so much power at your disposal, you can do more online, stream longer videos, and talk as much as you want without worry of getting through the day.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | ASUS ZenFone 4 Max (ZC554KL) - deepsea black - 4G smartphone - 32 GB - GSM | Product Type | 4G smartphone | Manufacturer Model Number | ZC554KL | Display | LCD display - 1280 x 720 pixels - 5.5" - IPS | Features | FM radio | Processor | Qualcomm Snapdragon 430 MSM8937 / 1.4 GHz (8-core) - 64-bit | Graphics Accelerator | Qualcomm ADRENO 505 | Memory | RAM 3 GB / 32 GB | Supported Memory Card | microSDXC slot - up to 256 GB | Operating System | Android 7.1.1 Nougat with ASUS ZenUI | Main Camera | 13 Megapixel - f/2.0 - focus: automatic laser auto focus: - laser focus | Second Camera | 5 Megapixel - wide-angle lens | Front Camera | 8 Megapixel - wide-angle lens - f/2.2 | Service Provider | Not specified | SIM Card | Dual-SIM - nano SIM | Wireless Interface | Wi-Fi, Bluetooth | Security Devices | Fingerprint reader | Messaging Services | SMS, MMS | Connectors | 3.5 mm headset jack, Micro-USB | Talk Time | Up to 2400 minutes | Standby Time | Up to 1104 hours | Colour | Deepsea black | Dimensions (WxDxH) | 76.9 mm x 8.9 mm x 154 mm | Weight | 181 g | Specific Absorption Rate (SAR) | 0.302 W/kg (head) , 1.2 W/kg (body) | Manufacturer Warranty | 2-year warranty |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Integrated Components | FM radio |
Width | 76.9 mm |
Depth | 8.9 mm |
Height | 154 mm |
Weight | 181 g |
Body Colour | Deepsea black |
Body Material | Metal |
SAR Value | 1.2 W/kg (body), 0.302 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Operating System | Android 7.1.1 Nougat |
User Interface | ASUS ZenUI |
Navigation | GPS, A-GPS, GLONASS, BeiDou |
SIM Card Type | Nano SIM |
SIM Card Qty | Dual-SIM |
Input Device | Multi-touch, capacitive |
Messaging & Internet | |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, LTE, FDD-LTE, TDD-LTE |
2G Band | 850 GSM, 1800 GSM, 1900 GSM |
3G UMTS Band | Band 1, Band 5, Band 8 |
3G UMTS Frequency | 2100, 850, 900 |
4G LTE Band | Band 1, Band 3, Band 5, Band 7, Band 8, Band 20, Band 40 |
4G LTE Frequency | FDD 2100, FDD 1800+, FDD 850, FDD 2600, FDD 900, FDD 800 DD, TDD 2300 |
Wireless Interface | IEEE 802.11b/g/n, Bluetooth 4.1 |
Phone Features | |
Phone Functions | Speakerphone, call timer, conference call, flight mode, vibrating alert |
Sensors | Ambient light sensor, proximity sensor, digital compass, gyro sensor, G-sensor |
Additional Features | Dual microphones, Google Drive Storage (100 GB) (free for 2 years), power bank function, ASUS PowerMaster |
Processor | |
Type | Qualcomm Snapdragon 430 |
Processor Number | MSM8937 |
Clock Speed | 1.4 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Graphics System | |
Memory | |
RAM | LPDDR3 SDRAM - 3 GB |
Internal Memory Capacity | 32 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 256 GB |
Front Camera | |
Sensor Resolution | 8 Megapixel |
Lens Type | Wide-angle lens |
Lens Aperture | F/2.2 |
Light Source | LED light |
Main Camera | |
Sensor Resolution | 13 Megapixel |
Lens Aperture | F/2.0 |
Focus Adjustment | Automatic |
Laser Auto Focus | Yes |
Camera Modes | Panorama, Pro mode |
Video Resolutions | 1920 x 1080 (1080p) at 30 fps |
Features | Phase Detect Auto-Focus (PDAF), Electronic Image Stabiliser (EIS), PixelMaster 4.0 camera, Instant cameras switching |
Second Camera | |
Sensor Resolution | 5 Megapixel |
Display | |
Type | LCD display |
Technology | IPS |
Diagonal Size | 5.5" |
Display Resolution | 1280 x 720 pixels |
Display Format | HD |
Colour Depth | 16.7 million colours |
Enhancement Technology | Blue light filter |
Features | 2.5D curved glass |
Connections | |
Connector Type | Headset jack - mini-phone 3.5mm , Micro-USB - 5 pin Micro-USB Type B |
Battery | |
Technology | Lithium polymer |
Capacity | 5000 mAh |
Talk Time | 2400 minutes |
Standby Time | 1104 hours |
Run Time Details | Talk: up to 2400 min , Standby: up to 1104 hrs , Playback (video): up to 22 hrs , Active online usage (Wi-Fi): up to 26 hrs |
Miscellaneous | |
Included Accessories | Headset, power adapter, OTG cable, micro-USB to USB cable |
Manufacturer Warranty | |
Service & Support | 2-year warranty |
