Samsung TV Promotion: Save up to £400 across the range.
Beats Studio Pro Wireless Headphones - Black
free standard delivery
£289.00
Colours:
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Experience immersive listening with Beats' most powerful custom acoustic platform
  • Sound that surrounds you with Personalized Spatial Audio and dynamic head tracking
  • Active Noise Canceling (ANC) continuously optimizes for immersive listening
  • Transparency mode blends your listening experience with the world around you
  • Enhanced Apple and Android compatibility with one-touch pairing and deeper ecosystem integration
  • More ways to connect - USB-C audio, Class 1 Bluetooth, and 3.5 mm audio input
  • Accessory Type: Over-Ear, Headphones / Earphones
  • Connectivity: Bluetooth, Wired, Wireless
  • Colour: Black
Product codes
chevron icon
chevron icon
Feel every emotion with Beats Studio Pro’s immersive listening experience. A fully custom acoustic platform provides powerful, balanced sound. Personalised Spatial Audio with dynamic head tracking delivers a 360 audio experience (1). When you want to silence distractions, Active Noise Cancelling adapts in real-time to neutralise the world around you. And when you want a more natural experience, Transparency mode seamlessly mixes the world outside with what you’re listening to. With up to 40 hours of battery life (2), enhanced Apple and Android compatibility (3), and flexible connectivity, every aspect of these headphones has been reimagined to keep you connected to the emotion behind the music for longer.
(1) Compatible hardware and software required. Works with compatible content in supported apps. Not all content available in Dolby Atmos. iPhone with TrueDepth camera required to create a personal profile for Spatial Audio, which will sync across Apple devices running the latest operating system software, including iOS, iPadOS, macOS and tvOS.
(2) Testing conducted by Apple in May 2023 using pre-production Beats Studio Pro units and software paired with iPhone 13 units and pre-release software. The playlist consisted of 358 unique audio tracks purchased from the iTunes Store (256 Kbps AAC encoding). Volume was set to 50% and Active Noise Cancelling and Transparency were turned off. Testing consisted of full Beats Studio Pro battery discharge while playing audio until Beats Studio Pro stopped playback. With Active Noise Cancellation turned on, listening time was up to 24 hours. Battery life depends on device settings, environment, usage and many other factors.
(3) Requires an iCloud account and a compatible Apple device running the latest operating system software or a compatible Android device running Android 8.0 or later, with Google Play Services enabled.
chevron icon
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been used but is in excellent condition
Ref: HCXC 048594
£210.49
product
Ref: HCXC 048594
Accessories
Packaging
Functional
Software
Manuals
£210.49
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£289.00
