ITEM | QTY | PRICE |
StarTech.com 12in Latching SATA to Ri...
3 | £17.49 |
Jabra GN2100 Kingsize Ear Kit
4 | £32.48 |
WD 1TB AV-GP SATA 6GB/s 3.5" 64M...
3 | £161.73 |
Keep your USB-C devices charged or easily sync music and photos from any USB-A port with durable USB-C to USB-A cables you can use just about anywhere. Made with enhanced braided nylon for added flexibility and strength, tested to withstand 10,000+ bends, and with USB-IF certification, you can count on worry-free performance.
You can find the perfect cable for any situation. Sync two devices across a room or connect your smartphone to a power bank in your pocket or backpack.
Product Description | Belkin BOOST CHARGE - USB-C cable - 24 pin USB-C to USB - 1 m | Type | USB-C cable | Features | Sync and charge, braided | Length | 1 m | Connector | 24 pin USB-C - male | Connector (Second End) | 4 pin USB Type A - male | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Jacket Material | Nylon |
Length | 1 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | USB-IF |
Dimensions & Weight (Shipping) | |
Service & Support | 2-year warranty |
