Charge your USB-C devices fast with the Belkin BPB001btBK 10000 mAh Portable Power Bank. With the support of Power Delivery, you get up to 18 W output. That's enough to charge a smarthone halfway in just about half hour. Then there's an additional classic USB port for an extra device.
Product Description | Belkin BOOST CHARGE power bank - USB, 24 pin USB-C - 18 Watt | Product Type | Power bank | Dimensions (WxDxH) | 1.65 cm x 14.348 cm x 7.46 cm | Colour | Black | Output Connector Type | Total 2: USB, 24 pin USB-C | Fast Charge Technology | Fast Charge, Power Delivery | Battery | 10000 mAh | Power Provided | 18 Watt | Cables | USB-C to USB-C cable - 15 cm | Manufacturer Warranty | 2-year warranty |
General | |
Designed For | Tablet, mobile phone |
Width | 1.65 cm |
Depth | 14.348 cm |
Height | 7.46 cm |
Enclosure Colour | Black |
Power Device | |
Output connectors | Total 2: 4 pin USB Type A, 24 pin USB-C |
Battery | |
Capacity | 10000 mAh |
Miscellaneous | |
Equipment Protection Value | 2500 US Dollars |
Cables Included | USB-C to USB-C cable - 15 cm |
Compliant Standards | USB-IF, MFI |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
