Belkin BOOST UP CHARGE Wireless Charging Pad 15W (with Power...
Belkin BOOST UP CHARGE Wireless Charging Pad 15W (with Power Supply) - White
£28.50
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fast wireless charging up to 15W
  • Case compatible up to 3mm
  • Qi certified to ensure safe charging
  • LED light indicates proper charging
  • Non-slip grip material keeps phone in place
  • 24W Quick Charge 3.0 power supply included
  • Stock Status: In Stock
Product codes
Designed to deliver fast wireless charging for the latest smartphones, the 15W BOOST?CHARGE Wireless Charging Pad couldn't be easier to use. Unclutter your bedroom, office, or kitchen counters by going wireless - just place your phone on the pad and start charging instantly. LED light indicators and non-slip surface keep your phone charging correctly, and a 24W Quick Charge 3.0 power supply unit is included.
Charge without removing your case. Belkin’s BOOST?CHARGE Wireless Charging Pad is engineered to work with lightweight plastic cases up to 3mm.
Power any Qi-enabled device using this single charger. The BOOST?CHARGE Wireless Charging Pad 15W has been engineered to fast charge Apple, Samsung, and Google smartphones while delivering 5W to all other Qi-enabled devices.
Constant calls and texts? No problem. The nonslip material helps to grip your iPhone, keeping it safely in place while charging.
Product Description Belkin BOOST CHARGE wireless charging pad - + AC power adapter - 15 Watt
Product Type Wireless charging pad + AC power adapter
Dimensions (WxDxH) 9.5 cm x 9.5 cm x 1.55 cm
Colour White
Fast Charge Technology Qualcomm Quick Charge 3.0
Wireless Charging Standards Qi
Power Provided 15 Watt
Power Device Details AC power adapter - 24 W
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£28.50
