Connect your USB-C laptop, to multiple USB devices with this comprehensive port expansion hub. Two USB-C ports connect devices, while two USB-A ports allow easy connection for existing devices, such as a hard drive, mouse, keyboard or printer. Small and compact, with a tethered USB-C cable, the hub is an ultimately portable and comprehensive peripherals solution.
Connect all your peripherals to your USB-C device with one compact hub. Two USB-A ports connect existing devices, and two dedicated USB-C ports for newer peripherals. Existing or new, your keyboard, mouse, flash drive or cable to sync other devices, will all find a home with this compact hub.
Connect your devices to the hub to sync, and enjoy data transfer of 5 Gbps. That's fast by any standard, let alone a multi-tasking hub that's the size of a pack of playing cards.
Product Description | Belkin USB-C 4-Port Mini Hub - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x SuperSpeed USB 3.0 | Features | USB powered | Compliant Standards | USB 3.0, USB 3.1 | Colour | Black |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Expansion / Connectivity | |
Interfaces | 2 x USB 3.0 Type A , 2 x USB 3.0 Type C , 1 x USB 3.0 Type C |
Miscellaneous | |
Colour | Black |
