Connect your netbook or laptop to your wireless network.
Compact Design
The compact design of the Surf+ N300 USB Wireless Micro Adapter makes it easy to connect to your laptop or netbook and go. It's so small you can easily leave it connected to your computer.
Easy Setup
Connect your computer to your modem or router without cables. Just plug the adapter into your computer's USB port and insert the setup CD, and you're ready to connect to the Internet from anywhere in your home.
Speed
Get wireless speeds ideal for surfing, emailing and instant messaging--up to 300Mbps.*
Simple Security
WEP and WPA/WPA2 security protocols and Wi-Fi Protected Setup (WPS) let you configure and secure your connection.
Backward-Compatible
Backward-compatible with 802.11g devices at 54 Mbps and 802.11b products at 11 Mbps, the Surf+ N300 USB Wireless Micro Adapter can connect to older wireless networks and hotspots as well as newer 802.11n networks and wireless-N devices that offer increased range and speed.
*The standard transmission rates--300Mbps, 54Mbps, and 11Mbps--are the physical data rates. Actual data throughput will be lower.
Product Description | Belkin SURF N300 USB Wireless N Micro Adapter - network adapter - USB 2.0 | Device Type | Network adapter | Form Factor | External | Interface (Bus) Type | USB 2.0 | Dimensions (WxDxH) | 1.8 cm x 3.6 cm | Weight | 10 g | Data Link Protocol | 802.11b/g/n | Data Transfer Rate | 300 Mbps | Frequency Band | 2.4 GHz | Compliant Standards | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | System Requirements | Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3 or later | Manufacturer Warranty | 2-year warranty |
General | |
Networking | |
Connectivity Technology | Wireless |
Data Link Protocol | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Features | WPS |
Aerial | |
Antenna | Internal |
Miscellaneous | |
Encryption Algorithm | 128-bit WEP, 64-bit WEP, WPA, WPA2 |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows XP SP3 or later |
Dimensions & Weight | |
Width | 1.8 cm |
Depth | 3.6 cm |
Weight | 10 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Humidity Range Operating | 0 - 90% (non-condensing) |
