Digital Cordless Telephone with Nuisance Call Blocking and Answering Machine
The BT 7660 Cordless Phone makes staying in touch at home easier, with no wires and ease of use, it's the perfect phone for all the family.
Basic call blocking features prevent nuisance calls from interrupting your day, plus its large wireless range means you can walk around the house without the phone signal dropping out. And don’t miss important messages when away from home, you can save up to 60 minutes of messages on the answering machine.
There's also a loudspeaker, and ringer with adjustable volume, and a screen with caller ID, so you can see who's calling before you pick up. The clock also has an alarm function, which makes the BT 7660 perfect for use as a bedside phone.
You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
The BT 7660 blocks numbers in two separate ways to help you avoid nuisance calls, firstly by type, e.g withheld or international, and also by your choice of specific numbers (you can store up to 100 numbers of your own choice)
DISPLAY
CALLING
FEATURES
POWER
Product Description | BT 7660 Single - cordless phone - answering system with caller ID | Product Type | Cordless phone answering system with caller ID | Total Number of Wireless Handsets | 1 | Speakerphone | Yes | Call Services | Caller ID |
General | |
Product Type | Cordless phone answering system |
Phone Features | |
Caller ID Type | Caller ID |
Dialer Location | Handset |
Additional Functions | Alarm, Do not disturb, Nuisance Call Block, up to 50 call blocking numbers |
Answering System | |
Recording Capacity | 60 min |
The following resources are available for the BT 7660 Single
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
