Advanced Phone Z with 100% nuisance call blocking and answer machine
The Advanced Phone Z, powered by trueCall’s award winning technology. Have complete control over which calls you want to take and those you want to block.
Nuisance Call blocking features
Avoid unwanted calls. Block up to 1000 specific numbers or use Do Not Disturb to silence your calls.
Easy set up and great sound quality
Get the most out of your phone straight away with our easy to use menu. And enjoy high quality clear calls.
Product Description | BT Advanced Phone Z Single - cordless phone - answering system with caller ID | Product Type | Cordless phone answering system with caller ID | Total Number of Wireless Handsets | 1 | Cordless Phone Standard | DECT\GAP | Speakerphone | Yes | Call Services | Caller ID, Call Waiting, Call Transfer, Call Block, Call screening | Display | LCD display - monochrome - Yes |
General | |
Product Type | Cordless phone answering system |
Phone Features | |
Caller ID Type | Caller ID |
Max Handset Operating Distance | 50 m |
Max Handset Operating Distance (Outdoor) | 300 m |
Dialer Location | Handset |
Conference Call Capability | Yes |
Volume Control | Yes |
Indicators | Visual ringer light, call waiting indicator |
Additional Functions | Call timer, built-in clock, Alarm, Intercom, remote access, keyboard lock |
Phone Memory | |
Phone Directory Capacity | 200 names & numbers |
Caller ID Memory | 30 names & numbers |
Answering System | |
Recording Capacity | 30 min |
Display | |
Type | LCD display - monochrome |
Display Location | Handset |
Diagonal Size | 1.8" |
Backlit | Yes |
Miscellaneous | |
Placing / Mounting | Table-top |
Battery | |
Battery | AAA type |
Capacity | 750 mAh |
Technology | Nickel Metal Hydride |
Talk Time | 22 h |
Standby Time | 240h |
Dimensions & Weight (Base) | |
Width | 11.4 cm |
Depth | 9.3 cm |
Height | 4.6 cm |
Weight | 123 g |
Dimensions & Weight (Handset) | |
Width | 5.2 cm |
Depth | 3.5 cm |
Height | 17.6 cm |
Weight | 119.4 g |
Dimensions & Weight (Power Adapter) | |
Width | 8.4 cm |
Depth | 7.8 cm |
Height | 4.1 cm |
Weight | 46.2 g |
