The Baby Monitor Pacifier comes with lightshow, MP3 connection, HD-sound and a wider range of lullabies - giving you even more peace of mind with your baby!
The Pacifier comes with a starry night projected light show combined with a wide-range of lullabies (from Mozart to `twinkle, twinkle' which have been proved to calm and relax babies. It also has an MP3 connection so that you can play the baby its favourite song -or yours!
Like the BT Baby Monitor 200 and 250, the Baby Monitor Pacifier has crystal clear HD sound, and a talk-back feature. It has a huge range of 50m indoors and 300m outdoors, and the temperature-changing nightlight on the monitor changes colour depending on the room temperature so that you can check at a glance. All of our monitors come with various modes of alerting you to sounds in the babies room - full sound monitoring, beeping, vibration, or flashing lights.
So when you want to watch TV or make the dinner in the other room, but want total reassurance that your baby is safe and sound in the cot, the new BT Baby Monitor Pacifier is the Baby Monitor for you.
Main Features
Product Description | BT Baby Monitor - baby monitoring system | Product Type | Baby monitoring system | Hi-Definition Sound | Yes | Lightshow | Yes | Auxillary MP3 input | Yes | Backlit Display | Blue | Torch | Yes | Temperature Changing Nightlight | Yes | Travel Bag | Yes | Colour | White/Purple | Sound Sensitivity LEDs | Yes | Wipeable Keys | Yes | Paging | Yes | Low Battery Alert | Yes | Battery Type | NiMH | Belt Clip | Yes | Volume Control | Yes | Wall Mount | No | Clock | No | Vibrating Alert | Yes | Timer | Yes | Talk Back | Yes |
General | |
The following resources are available for the BT Baby Monitor Pacifier
