ITEM | QTY | PRICE |
LG 50" UR7800 4K Ultra HD Smart TV
3 | £897.00 |
with 100% call blocking and answer machine
Featuring
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Call blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. This means any caller not on your contact list or already blocked will have to announce their name before getting through so you can choose whether to accept or reject the call. You can also choose to block certain types of call like international or withheld numbers.
Using Bluetooth®, you can sync all your contacts between your mobile and Premium Phone and even make and receive your mobile calls through your landline.
You can save up to 1000 contacts and these are automatically copied to all handsets if you buy a multi pack or register extra handsets. Outgoing call control lets you set a PIN to protect calls to mobile, international and premium rate numbers to prevent any surprises on your bill.
Save up to 60 minutes of messages. You can playback your messages privately through the handset or using the handsfree speaker. And don’t miss important messages when away from home with remote access to your messages.
Product Description | BT Premium Phone Twin - cordless phone - answering system with caller ID + additional handset - 3-way call capability | Product Type | Cordless phone answering system with caller ID + additional handset | Total Number of Wireless Handsets | 2 | Cordless Phone Standard | DECT\GAP | Speakerphone | Yes | Call Services | Caller ID, Call Transfer, Call Block | Display | LCD display - colour - Yes |
General | |
Product Type | Cordless phone answering system |
Additional Handsets Qty | 1 |
Shipping Weight | 909.2 g |
Phone Features | |
Caller ID Type | Caller ID |
Max Handsets Supported | 6 |
Max Handset Operating Distance | 50 m |
Max Handset Operating Distance (Outdoor) | 300 m |
Dialer Location | Handset |
Conference Call Capability | 3-way |
Volume Control | Yes |
Ring Tones | 15 |
Polyphonic Ringer | Yes |
Indicators | Visual ringer light |
Additional Functions | Call timer, built-in clock, Alarm, Intercom |
Phone Memory | |
Phone Directory Capacity | 200 names & numbers |
Dialed Calls Memory | 30 |
Answering System | |
Recording Capacity | 60 min |
Display | |
Type | LCD display - colour |
Display Location | Handset |
Diagonal Size | 1.8" |
Backlit | Yes |
Miscellaneous | |
Placing / Mounting | Table-top |
Battery | |
Battery | AAA type |
Capacity | 750 mAh |
Technology | Rechargeable - Nickel Metal Hydride |
Talk Time | Up to 1260 min |
Standby Time | Up to 240 h |
Dimensions & Weight (Base) | |
Width | 7.7 cm |
Depth | 3.5 cm |
Height | 9.3 cm |
Weight | 123.6 g |
Dimensions & Weight (Handset) | |
Width | 5 cm |
Depth | 4 cm |
Height | 18.9 cm |
Weight | 116.8 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 21.5 cm |
Shipping Depth | 9.4 cm |
Shipping Height | 19 cm |
The following resources are available for the BT Premium Phone - Two Handsets
