Buffalo's TeraStation 1400 is a compact, budget friendly four drive desktop network storage solution ideal for small businesses, home offices and professional users requiring a reliable RAID-based network storage solution for business networks and power users.
Product Description | BUFFALO TeraStation 1400 - NAS server - 16 TB | Device Type | NAS server | Bundled Services | 3 years 24-hour TeraStation VIP HDD Exchange Service | Host Connectivity | Gigabit Ethernet | Enclosure Type | Rack-mountable | Total Storage Capacity | 16 TB | Max Supported Capacity | 16 TB | Installed Devices / Modules Qty | 4 (installed) / 4 (max) | Dimensions (WxDxH) | 43 cm x 42 cm x 4.43 cm | Weight | 9 kg () | Processor | 1 x Marvell ARMADA 370 1.2 GHz (Dual-Core) | Storage Controller | RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 4 x 4 TB SATA 3Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | RAM | 512 MB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Linux | System Requirements | Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Microsoft Windows RT 8.1, Apple MacOS X 10.4 - 10.9 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 43 cm |
Depth | 42 cm |
Height | 4.43 cm |
Weight | 9 kg () |
Processor / Memory | |
Processors Installed | 1 x Marvell ARMADA 370 1.2 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 512 MB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 3Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD - hot-swap |
Capacity | 4 x 4 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP |
Remote Management Protocol | HTTP, HTTPS |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS |
Features | LDAP support, FTP server, Buffalo Web Access, Apple Time Machine compatible, NTP time synchronisation, SFTP server |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab |
Expansion / Connectivity | |
Expansion Bays | 4 (total) / 0 (free) x hot-swap |
Interfaces | 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A |
Miscellaneous | |
Features | Device-to-device data replication |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 140 Watt |
Software / System Requirements | |
Software Included | NovaBACKUP Business Essentials (10 licences) |
OS Required | Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Microsoft Windows RT 8.1, Apple MacOS X 10.4 - 10.9 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
