Marketing description is not available.
Product Description | BUFFALO TeraStation 5010 Series TS51210RH4004 - NAS server - 40 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet / 10 Gigabit Ethernet | Enclosure Type | Rack-mountable - 2U | Total Storage Capacity | 40 TB | Dimensions (WxDxH) | 48.1 cm x 73.7 cm x 8.79 cm | Weight | ) | Localisation | Europe | Processor | 1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD | Hard Drive | 4 x 10 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE | RAM | 8 GB | Power | AC 120/230 V (50/60 Hz) | Power Redundancy | Optional | Storage Operating System | Linux | System Requirements | Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9 or later, Microsoft Windows Server 2016, Microsoft Windows 7 / 8.1 / 10 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 48.1 cm |
Depth | 73.7 cm |
Height | 8.79 cm |
Weight | ) |
Processor / Memory | |
Processors Installed | 1 x Annapurna Labs Alpine AL-314 1.7 GHz |
Number of Cores | Quad-Core |
RAM | 8 GB DDR3 |
Features | ECC |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD |
Hard Drive | |
Type | HDD - hot-swap |
Capacity | 4 x 10 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE |
Remote Management Protocol | SNMP |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), SFTP |
Features | Apple Time Machine compatible, cloud backup, Dropbox support, boot authentication, Rsync compatible |
Encryption Algorithm | 256-bit AES |
Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz |
Expansion / Connectivity | |
Expansion Bays | 12 (total) / 8 (free) x hot-swap |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 2 x Ethernet 10Gb - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A |
Miscellaneous | |
Features | Web management, VMware Ready |
Included Accessories | Rack mounting kit |
Power | |
Power Device | Internal power supply - hot-plug |
Installed Qty | 1 |
Max Supported Qty | 2 |
Power Redundancy Scheme | 1+1 (with optional power supply) |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 122 Watt |
Power Consumption Stand by | 3.9 Watt |
Software / System Requirements | |
Software Included | NovaBACKUP Buffalo Edition |
OS Required | Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.9 or later, Microsoft Windows Server 2016, Microsoft Windows 7 / 8.1 / 10 |
Manufacturer Warranty | |
Service & Support | Limited warranty - technical support - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 85% (non-condensing) |
