Buffalo's TeraStation 5800DWR series delivers top-of-class 8-bay Network Attached Storage and comes fully populated with high-reliability WD Red drives: perfect for production environments, medium, large, and growing businesses, and overall demanding users.
The TS5800DWR performs exceptionally during file transfers and everyday NAS functions thanks to its powerful Intel Atom D2700 dual core processor, 2 GB of fast DDR3 memory, and five USB ports - including two USB2.0 and three SuperSpeed USB 3.0.
Product Description | BUFFALO TeraStation 5800DWR - NAS server - 48 TB | Device Type | NAS server | Bundled Services | 3 years 24-hour TeraStation VIP HDD Exchange Service | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 48 TB | Max Supported Capacity | 48 TB | Installed Devices / Modules Qty | 8 (installed) / 8 (max) | Dimensions (WxDxH) | 30 cm x 21.5 cm x 23 cm | Weight | 12.5 kg () | Processor | 1 x Intel Atom D2700 2.13 GHz (Dual-Core) | Storage Controller | RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, 50, JBOD, 60, 51, 61 | Hard Drive | 8 x 6 TB SATA 3Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | RAM | 2 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | Linux | System Requirements | Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.4 - 10.9 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 30 cm |
Depth | 21.5 cm |
Height | 23 cm |
Built-in Devices | Status LCD |
Processor / Memory | |
Processors Installed | 1 x Intel Atom D2700 2.13 GHz |
Number of Cores | Dual-Core |
Max Supported Qty | 1 |
RAM | 2 GB DDR3 |
Storage Controller | |
Type | RAID |
Interface Type | SATA 3Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, JBOD, RAID 60, RAID 51, RAID 61 |
Hard Drive | |
Type | HDD - hot-swap |
Capacity | 8 x 6 TB |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, UDP/IP |
Remote Management Protocol | HTTP, HTTPS |
Network Services Compatibility | Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS |
Features | LDAP support, wake on LAN (WOL), DFS support, FTP server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server |
Compliant Standards | DLNA CERTIFIED |
Expansion / Connectivity | |
Expansion Bays | 8 (total) / 0 (free) x hot-swap |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x serial - DB-9 |
Miscellaneous | |
Features | Device-to-device data replication, Citrix Ready |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 170 Watt |
Software / System Requirements | |
Software Included | NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server |
OS Required | Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Apple MacOS X 10.4 - 10.9 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 35 °C |
Humidity Range Operating | 20 - 80% (non-condensing) |
