Replace your overused or misplaced power cable, or just get some extra cords for convenience. This universal power cord is designed to work with most desktop PCs, monitors, scanners, printers and other devices that use the 3-pin shroud power connector. Plus this heavy-duty 16 AWG cord features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into a standard outlet.
Product Description | C2G Universal Power Cord - power cable - BS 1363 to power IEC 60320 C13 - 50 cm | Type | Power cable | Features | Molded | Length | 50 cm | Connector | Power BS 1363 - male | Connector (Second End) | Power IEC 60320 C13 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
American Wire Gauge (AWG) | 16 |
Features | Molded |
Length | 50 cm |
Colour | Black |
Connectivity | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
