We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Experience 4K ULTRA HD displays with this USB-C to DisplayPort Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet, smartphone or other device, and the DisplayPort input of a projector or display – making it an ideal solution for the office, work space applications or classrooms. This adapter utilises the audio/video capabilities built into USB Type-C ports to feed an audio/video signal to a DisplayPort monitor to achieve high quality, 4K (ULTRA HD) video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient solution that eliminates the need for a separate adapter or additional cabling, offering a straightforward installation.
Product Description | C2G 0.9m (3ft) USB C to DisplayPort Adapter Cable White - 4K Audio / Video Adapter - external video adapter - white | Device Type | External video adapter | Bus Type | USB-C | Max Resolution | 3840 x 2160 | Interfaces | DisplayPort (male connector) | Length | 90 cm | Enclosure Colour | White | Manufacturer Warranty | 3-year warranty |
General | |
Bus Type | USB-C |
Graphics Engine | Chrontel CH7213A |
Max Resolution | 3840 x 2160 at 30 Hz |
Miscellaneous | |
Compliant Standards | Plug and Play, Directive 2011/65/EU |
Length | 90 cm |
Weight | 49 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 50 °C |
Humidity Range Operating | 25 - 70% |
