This adapter converter is an ideal solution for converting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a VGA input. This adapter converter carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description | C2G 20cm Mini DisplayPort to VGA Adapter - Thunderbolt to VGA Converter M/F - Black - VGA adapter - 20 cm | Type | VGA adapter | Length | 20 cm | Connector | Mini DisplayPort - male | Connector (Second End) | HD-15 (VGA) - female | Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Length | 20 cm |
Colour | Black |
Connectivity | |
Connector (Second End) | 15 pin HD D-Sub (HD-15) - female |
Manufacturer Warranty | |
Service & Support | 3-year warranty |
