Make your work environment more flexible and efficient. This heavy-duty 14 AWG cord works with monitors, scanners, printers, and other devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully molded design for maximum durability and long life.
The female connector plugs directly into the device while the male connector plugs into another power cord or auxiliary power port on power supply for auto power when the system is turned on.
Product Description | C2G - power extension cable - power IEC 60320 C13 to IEC 60320 C14 - 1.8 m | Type | Power extension cable | Length | 1.8 m | Connector | Power IEC 60320 C13 | Connector (Second End) | Power IEC 60320 C14 | Rated Voltage | AC 250 V | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
American Wire Gauge (AWG) | 14 |
Length | 1.8 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
