C2G USB C to Gigabit Ethernet Network Adapter
Key features
  • Adds a wired network connection for Internet access
Product codes
chevron icon
chevron icon
The USB-C to Gigabit Ethernet Network Adapter is an ideal solution for converting an existing USB Type-C port on your laptop, Chromebook, tablet or other USB-C enabled device to a RJ45 Gigabit Ethernet port for a wired network connection to the Internet. This adapter utilises the high bandwidth of the USB-C port to support true Gigabit Ethernet speeds. This flexible solution requires no external power supply - simply connect the adapter to an available USB-C port, and connect a Cat5 cable from the adapter to an RJ45 Network port for a straightforward installation. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in first time, every time, whilst preventing damage to the port. With speeds up to 1000Mbps, file transfer between computers is fast and easy, even with very large files or large amounts of multimedia data. The adapter is a great solution for more modern computers that do not provide a wired Ethernet port or have a damaged Ethernet port.
chevron icon
Product Description C2G USB C to Ethernet Network Adapter - USB Type C to Gigabit Ethernet Adapter - network adapter - USB 3.0 - Gigabit Ethernet x 1
Device Type Network adapter
Form Factor External
Interface (Bus) Type SuperSpeed USB 3.0
Ports Gigabit Ethernet x 1
Dimensions (WxDxH) 2.34 cm x 7.66 cm x 1.56 cm
Weight 27.8 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate 1000 Mbps
Compliant Standards USB 3.1
Colour Black
System Requirements Apple MacOS, Microsoft Windows 7 / 8 / 8.1
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
