Sleek and slim, the DR-C225 II is made for tight spaces. With CaptureOnTouch software for even better usability, it's a true scanning solution.
Product Description | Canon imageFORMULA DR-C225 II - document scanner - desktop - USB 2.0 | Device Type | Document scanner - desktop | Interface Type | USB 2.0 | Scanning Sensor Type | CMOS / CIS | Light Source | RGB LED | Input Type | Colour | Grayscale / Color Depth | 8-bit (256 grey levels) / 24-bit (16.7 million colours) | Optical Resolution | 600 dpi x 600 dpi | Max Document Scan Speed | 25 ppm (mono) / 25 ppm (colour) | Automatic Duplexing | Yes | Document Feeder Type | Automatic | Document Storage Capacity | 30 sheets | Duty Cycle | 1500 scans per day | Power | AC 120/230 V (50/60 Hz) | System Requirements | Apple MacOS, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Android, Windows 8, Apple iOS, Windows 10 | Dimensions (WxDxH) | 30 cm x 15.6 cm x 22 cm | Weight | 2.8 kg | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 2-year Limited Warranty |
General | |
Scanner | |
Grayscale Depth | 8-bit (256 grey levels) |
Colour Depth | 24-bit (16.7 million colours) |
Bulb / Light Source Type | RGB LED |
Max Document Scan Speed B/W | 25 ppm |
Max Document Scan Speed Colour | 25 ppm |
Scanner Speed Details | 25 ppm - black & white , 50 ipm - duplex - black & white , 25 ppm - colour , 50 ipm - duplex - colour |
Scanner Features | Ultrasonic Double Feed Detection, Error Diffusion, Moire Reduction, automatic page size detection, blank page skipping, MultiStream Technology, Advanced Text Enhancement, Text Orientation Recognition, RGB Color Dropout, Smooth Background, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Image Rotation, Deskew, Auto Resolution, Red Color Enhancement, Erase Shadow, Pre-Scan, Job Setting, Ultrasonic sensor |
Compliant Standards | TWAIN, ISIS |
Media Handling | |
Expansion / Connectivity | |
Interfaces | USB 2.0 - Type B |
Miscellaneous | |
Cables Included | USB cable |
Compliant Standards | RoHS |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Power | |
Power Device | External power adapter |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational (Standby) | 12.7 Watt |
Power Consumption Sleep | 1.8 Watt |
Software / System Requirements | |
Software Included | Drivers & Utilities, Cardiris, Canon CaptureOnTouch, Nuance eCopy PDF Pro Office, Google Docs, SharePoint for Windows, SharePoint for Mac, EMC Captiva Cloud Runtime Controls, Google Docs for Mac, SugarSync, Dropbox |
OS Required | Apple MacOS, Microsoft Windows 2000, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows 7, Microsoft Windows Vista, Android, Windows 8, Apple iOS, Windows 10 |
Dimensions & Weight | |
Width | 30 cm |
Depth | 15.6 cm |
Height | 22 cm |
Weight | 2.8 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 32.5 °C |
Humidity Range Operating | 20 - 80% |
Manufacturer Warranty | |
Service & Support | 2-year Limited Warranty |
